Old 10-11-11, 10:17 AM   #51
TamSV
TamSV's Avatar
Default Re: Tools - opinion and help needed
Can you get access to saw or dremel a slot in the screw? You can then use a flat bladed screwdriver to get them out. Cut the slot as deep as you can into the head of the screw.
Old 10-11-11, 10:21 AM   #52
Winder
Winder's Avatar
Tried the cutting a slot with jnr hack saw but couldn't get deep enough, will try borrow a dremmel.
Last time I tried to drill something out it was a snapped bleed nipple, that didn't go well as the new nipple just leaked and I had to get a new caliper off Mr Husky
Old 10-11-11, 10:43 AM   #53
NTECUK
NTECUK's Avatar
If you drill the head off and leve the shank you can sometimes get moles on it.
Get a quality screwdriver.it helps allot and soaking with viniger when its in allot helps too.
Old 10-11-11, 07:43 PM   #54
Knock it round with punch and chisel, but first
www.youtube.com/watch?v=uc7uyMs-YtQ
Old 11-11-11, 08:48 PM   #55
alfa.rbt
I don't know if I did a right thing, but I bought a 1/2in socket set than no one recommended here. I went to motorist discount shop in Newbury and spotted nice set reasonably priced and I didn't think twice. Any one heard about Kamasa tools?? Anyone have them?? what do you think.
Ps Main thing that convinced me to buy it was 72 teeth ratchet.
http://www.kamasa.co.uk/item.aspx?cat=465&item=5254
Old 11-11-11, 09:00 PM   #56
timwilky
timwilky's Avatar
Kamasa are reasonable "value" tools, You should be OK with them
Not Grumpy, opinionated.
Old 11-11-11, 09:06 PM   #57
alfa.rbt
considering I'm no full time mechanic I believe It's not bad buy for 54 quid
Old 11-11-11, 09:21 PM   #58
I've got some Kamasa spanners I can't fault them
I've had them for over 20 years, not rusted or worn out with plenty of use in that time
So +1 to Tim's comment
Old 11-11-11, 09:24 PM   #59
alfa.rbt
Old 12-11-11, 04:24 PM   #60
embee
embee's Avatar
Kamasa have certainly been around for a long time, assuming the name hasn't just been "passed around" different owners so to speak. My Dad has a socket set by them, must be 20yrs of occasional use by now, it's fine.
Flywheel puller and engine removal tools needed. Mike_84_650S'99 SV Talk, Tuning & Tweaking 2 21-10-11 11:52 PM
air compresser for air tools advice needed barwel1992 Idle Banter 5 03-07-11 04:19 PM
Replacing Clutch - which tools needed? bengodden SV Talk, Tuning & Tweaking 1 01-02-11 12:56 PM
valentines day : blokes opinion needed jenni Idle Banter 30 18-02-07 01:02 AM
any special tools needed for clutch investigation work? grecian9 SV Talk, Tuning & Tweaking 3 22-09-06 03:04 PM
