Old 01-03-09, 08:10 PM   #61
paiste
Default Re: Sorry to ask but...rear shock?
Does anyone know where I can find the link for the spreadsheet which lists all the compatable shocks with their length, spring rate etc?
I know I've seen it on here somewhere but I just cant find it
Thanks in advance
Old 01-03-09, 08:12 PM   #62
Mr Speirs
Mr Speirs's Avatar
here ya go
YEAR MOTORCYCLE LENGTH SPRING
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 325#
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
<end>
Old 01-03-09, 10:10 PM   #63
paiste
Thank you
Old 09-04-09, 01:12 AM   #64
Wraith_017
would a Busa shock be adjustable for a 150 lb rider?
Old 09-04-09, 08:59 AM   #65
Luckypants
Luckypants's Avatar
No, it will be WAY too stiff. The Busa shock is too stiff for a pointy (2003 on) unless you are VERY, VERY heavy. For a curvy (99-02) the spring rates are higher due to different linkage, but the Busa shock is still only suitable if you are over 16st (225lbs) IMHO.
Use the table above to find a shock with a spring rate similar to stock, as that is pretty close for a 11st (150lb) rider.
Old 09-04-09, 09:03 AM   #66
plowsie
Agreed. If your like me then your good.
Rear shock 03-08 silent11 For Sale - SV's and SV related items 0 17-05-08 02:53 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
rear shock socommk23 Bikes - Talk & Issues 1 23-04-07 05:09 PM
Rear shock latts650s SV Talk, Tuning & Tweaking 1 09-08-05 09:17 AM
Rear shock sprocket SV Talk, Tuning & Tweaking 3 17-05-05 10:50 PM
