Old 16-02-10, 10:02 AM   #61
wyrdness
Default Re: Hmmm, Restriction done, but did it work?
But 2 of them make children fall over, which is hilarious
Up to you, I like relay solution. The stock wiring is prone to weakness when you pull a lot of current through it.
Point 1 - ROFL
Point 2 - But a magnum doesn't pull a lot of current. I carefully read the manufacturers data sheet before fitting one (to my Speed Triple) to make sure that it wouldn't fry the wiring.
Old 16-02-10, 10:04 AM   #62
But that is assuming the stock wiring has the balls to supply the stock horn!
Basically anything is a lot of current compared to the miniscule amount needed to operate a relay.
Old 16-02-10, 10:58 AM   #63
wyrdness
Absolutely true. Exhibit A - my winter hack Dullville. The electrical system can barely cope with the stock meeper.
Old 16-02-10, 09:09 PM   #64
Jayneflakes
Jayneflakes's Avatar
Get pair of stebel magnums, they do the trick.
Originally Posted by wyrdness View Post
A single magnum is plenty loud enough.
This folks is why I love the Org...
"Too much is never enough!" to quote my favourite magazine from when I was at Uni in the late 90's.
Thank you guys, as usual there is some brilliant advice there and some down right meanness which is always good.
Jayne you're a Pussy Magnet
Old 16-02-10, 09:49 PM   #65
Baph had 2x magnums and some air horns off a truck or something at one point. That was ridiculous, it sounded like a train.
Old 16-02-10, 09:52 PM   #66
ophic
ophic's Avatar
Kind of like the nose gun off an A-10. Hold the button for too long, and you end up going backwards
Silver SV650SK3, Fuel exhaust
Old 16-02-10, 09:54 PM   #67
Yeah cars couldn't help but notice if they pulled out on him 'cos the side window ended up in the tattered and bloodied remnants of their inner ear.
Old 16-02-10, 10:27 PM   #68
Jayneflakes
This sounds awesome, although it probably is best not to actually hear it! I so need to look into rigging up something like this. I want something that produces the infamous brown note. That should sort out the rude drivers who pull out on me or cut me up on the road!
Old 16-02-10, 10:49 PM   #69
fastdruid
fastdruid's Avatar
Just have to ensure there is no er back scatter
Druid
Old 16-02-10, 10:56 PM   #70
ophic
ophic's Avatar
Druid
perfect application for crotchless chaps.
Hmmm what do I do FG1 Bikes - Talk & Issues 15 08-05-07 09:52 PM
HMMM What have you been up to ? Blue Flame Idle Banter 0 08-09-06 02:45 PM
Hmmm....looks tricky TC3 Idle Banter 3 21-05-06 08:34 AM
