Old 22-05-10, 09:54 PM   #61
petevtwin650
Default Re: Aftermarket brake disc opinions?
Unless you rarely use brakes, in which case why upgrade then
Brakes do more than slow you down YC, or not if it's an SV
Lighter discs are supposed to be advantageous to handling. I rarely used my SV's brakes but the Braking Wavy's looked fabulous IMO.
Anyway what problem is Dave numbers gonna have? They make the rest of the bike look tired maybe?
Old 23-05-10, 09:43 AM   #62
I must have missed that part of my vehicle design course, what else do brakes do?
Lighter discs are good for handling, suspension etc. but for the difference in weight between a heavy disc and a light one I doubt you or I could notice.
Problem Dave might have is speedo needle wibbling due to changing frequency from odd disc magnet spacing.
Old 23-05-10, 09:46 AM   #63
mjc
cmon chris I'm a year behind you and even I know they're for stoppies
wibbling
Technical term?
Old 23-05-10, 09:59 AM   #64
Stoppy is just what happens when F(static,rear) - (Mass*Decel*H)/wheelbase = 0
Which is function of slowing down, quickly
[/geek]
Technical term?
You knows it.
Old 23-05-10, 11:05 PM   #65
ThEGr33k
What's point of best calipers and pads ever if you still on stock master cyl?
Further, the stock master is the same Brembo item used on most bikes upto the radial revolution... incase you thought it was a cheaper item?
Anyway, dave, how are the disc's? Everything back together?
One other question, how long you have to wait for order to be delivered?
Cheers!
Old 23-05-10, 11:07 PM   #66
It is cheaper item compared to top of line RCS or whatever else
Old 23-05-10, 11:41 PM   #67
ThEGr33k
Can't disagree. Oh well another item on the list huh.
Old 24-05-10, 12:55 AM   #68
barwel1992
And when you get your radial MC i will nab your old one off you (for some ££)
Old 24-05-10, 08:17 AM   #69
ThEGr33k
Might be a while Barwel but sure.
Old 24-05-10, 08:18 AM   #70
barwel1992
cool
Brake disc jack930 Stuff Wanted 2 13-10-09 10:00 AM
MOT - brake disc thickness DarrenSV650S Bikes - Talk & Issues 18 24-01-09 12:03 PM
Just ordered a set of brake hoses - opinions? sv_rider1990 SV Talk, Tuning & Tweaking 8 24-06-08 12:15 PM
front brake disc leemole Stuff Wanted 1 17-08-07 06:52 PM
Aftermarket brake pads.. verticaldip SV Talk, Tuning & Tweaking 5 14-06-05 08:54 AM
