Old 07-02-16, 07:08 PM   #191
Default Re: SV special build - S-pokey-V.
Sorry yes we have
Sent from my E2303 using Tapatalk
Old 19-02-16, 08:30 PM   #192
millemille
So, fuel cell fabrication...
I've been thinking long and hard how to go about creating an aluminium fuel cell that can also support a seat unit in place of a sub frame. Aluminium tanks are pretty fragile and very few of the respected tank fabricators use the tank as seat, most preferring at least some form of minimalist sub frame or a self supporting seat unit.
When the aluminium sheet for the tank was being delivered and watching 2 blokes try and restrain a 2m x 3m very flexible sheet of 1.5mm ally in a howling gale I had a eureka moment*.....
First of all, a cross member of 25mm dia ally was machined with M10 threads in each end face...
Then a "spine" in the profile of the fuel cell was cut from 3mm ally sheet, to match the profile of the modified original tank when measured along the centre line....
This will be welded to the center of the cross member and will carry, along with the side plates, the vertical load of the rider on the seat....
The top of the rear section is also 3mm ally and will carry a machined plate which the seat unit will bolt to. The spine will be cut out more to remove unnecessary material. The bottom of the rear section has been bent from 1.5mm ally, because it won't be carrying any structural load, only the weight of the fuel. The spine doesn't go to the bottom so that fuel can flow from either side of the spine to the fuel tap.........
The side plates for the rear sections will be cut to match the profile of the lower curved section once the lower section is welded to the spine...
*they were carrying it upright against the wind and it was bending and flexing and uncontrollable, so they turned it edge on the ot the wind and it was rigid and unmoving...
The front of the fuel cell will be mounted on this cross member....
The triangular pieces - left over from an aborted attempt at the silencer mounting - will be welded to the frame in the position shown. The 12mm dia cross member will be attached to the underside of the fuel cell.
So far all of the parts, before the spine is fully lightened and the side plates are cut away, weighs a smidge over 1.5kg. So I'm on track for the fuel cell itself weighing 3kg....
millemille is offline   Reply With Quote
Old 19-02-16, 08:31 PM   #193
millemille
After the 1st welding session...
Old 19-02-16, 08:43 PM   #194
Superb!
Old 19-02-16, 09:03 PM   #195
Superb
You sure your not an engineer for an F1 team
Old 19-02-16, 09:14 PM   #196
millemille
Superb
Only if F1 cars look like this now....
Old 20-02-16, 06:58 AM   #197
Ah that makes sense.
Old 22-02-16, 08:14 AM   #198
shiftin_gear98
shiftin_gear98's Avatar
Where's the damn like button on this thing.
LIKE.
Currently driving a Corsa....
Old 22-02-16, 01:19 PM   #199
Redmist
Redmist's Avatar
Amen, brilliant work!!
http://www.pegdownracing.com/
Want a Gyrocam for your track / road / racing videos? Gyrocam here!
Bikes: Minitwin SV650 '04. Click me!
SV650 (Now Nekked!) '04. Pictures here!
Redmist is offline   Reply With Quote
Old 08-03-16, 08:42 PM   #200
millemille
Decided to tack the whole thing together first and then fully weld it once tacked together....
gsxr build sv650nutter149 Thames Valley 21 12-05-10 07:22 AM
Hello! I have a few questions regarding a special build. NcSv SV Talk, Tuning & Tweaking 50 08-09-09 11:47 PM
For Hovis-Gid-Stretchie-Wideboy , just a special thought for you guys on this special day xXBADGERXx Idle Banter 21 24-07-09 04:26 PM
About to build one of these SV-net Idle Banter 14 22-11-08 04:14 PM
VW build quality kwak zzr Idle Banter 17 03-12-07 09:44 AM
