12-03-08, 08:58 PM | #1 |
Front caliper bolts.
My front brake calipers are in a bit of a cosmetic state. The torx bolts that seem to hold it all together have not suffered the past few winters too well. Is it wise to undo these. Was planning to initially try some elbow grease on them or once that proved too difficult, get some replacement bolts. Question is do they come out and if I take each one out, clean or replace then put it back do I end up with bits of brake caliper all over my drive?
If it all gets too hard may have to go for the more cowboy approach of just painting over the rust with black paint until I find some new calipers at the right price.
Don't want to be the quickest; don't want to be the best; just want to be the one having the most fun. XL125Varadero -> Curvy SV650N-Y -> SV1000N-K3 -> Multistrada 1200s Twin-tastic stuff. Minister for Sustainability Aliquid prudentissimus delectabiles et intelligentes in adamasset lingua. |
12-03-08, 09:31 PM | #2 |
Re: Front caliper bolts.
I'm just after doing that exact job on Project Triumph and it went a whole lot better than I expected. First up give it plenty Plus Gas or similar and leave that to work its miracle, then attack the bolts with a Tx Star socket bit on the end of a good size breaker bar, but gently now and let the leverage do the work. Out one at a time, coppaslip and back in at the correct torque. Easy.
But if I were you I'd wait for Northy, Yorkie Chris, Spannerman, Rictus... |
12-03-08, 09:39 PM | #3 | |
Them bolts do hold the caliper together can be a bit of a git if they're siezed in. Be careful when you take them out as if you shear them then it can take quite a bit of work. If they're anything like SRAD calipers then you'll be able to get to the back of the bolts and fill the recesses (with the caliper flat on the floor/bench) with penetrant oil. I don't see a reason why you shouldn't remove then replace and retighten them all in turn. BUT if you see any fluid loss, then bleed the lot just to be on the safe side. Copper slipping them is IMO alright, but wurth brake grease or other alloy based stuff could be better. Bear in mind that with copper slip or any liquid involved the torque settings are meaningless, reduce them by 10% for this.
13-03-08, 01:11 PM | #4 |
13-03-08, 02:00 PM | #5 |
Aye, I did the exact same thing with my old calipers- same as yours- just did it one at a time. I used stainless ones which obviously is not generally recommended but I'm notoriously slipshod and reckless so it didn't bother me too much, and I didn't die
Help - Front Caliper Mounting Bolts | SV Meldrew | SV Talk, Tuning & Tweaking | 19 | 11-02-09 08:13 AM |
Where can I buy caliper mounting bolts? | Binky | SV Talk, Tuning & Tweaking | 4 | 07-08-08 10:46 AM |
Caliper mouting bolts - Threadlock or Coppaslip? | Tiger 55 | SV Talk, Tuning & Tweaking | 13 | 16-02-08 02:48 AM |
Banjo Bolts on SV650 Caliper M10 x1 or M10 x1.25 ? | SpankyHam | SV Talk, Tuning & Tweaking | 5 | 24-05-06 09:41 AM |
Rear Brake Caliper Retaining bolts **WARNING** | derbybiker | SV Talk, Tuning & Tweaking | 11 | 07-10-04 01:00 PM |
