31-07-05, 04:40 PM | #1 |
Front Brake Switch - is it me??
Has anyone else had the front brake switch play up, or is it just me?
Took my H0nd@ in for MOT, having checked everything over beforehand, only for the front brake switch to play up and the light only flashed on briefly. I have a very understanding MOT man who said yes, he saw it work (for a few millisecionds anyway ). At home, checked it out and just as the lever was moved a fraction the light would come on, but when the lever was moved more it went off again. Took the switch off and took it apart. They are not made to come apart, but will! there are 3 plastic pillars inside one half which go through holes in the other, and are then melted over. Careful prising with a stanley knife and screwdriver and they pop out! The contacts are over-centre things, which then wipe across as the button moves further. Black dirt on the contacts meant that the first point made contact and the light came on, but then it moved onto a dirty part and it went off. The contacts are very soft (silver alloy?) material, so very gently cleaned them, covered in vaseline, checked electrical contact, and refitted. Now all seems fine. OK, you say, that was a H0nd@, what do you expect. ......except the SV uses the same switch and that didn't work either when I checked it! Same problem, cleaned/lubed and it seems OK. Is it just me, or is this more common? |
31-07-05, 04:55 PM | #2 |
I had the little stalk that the lever contacts snap off, on my way to the MOT... but the switch has been reliable.
31-07-05, 09:53 PM | #3 |
must be you.
how dare you insult mr hondas work of art |
31-07-05, 10:12 PM | #4 | |
guess so |
31-07-05, 10:22 PM | #5 |
31-07-05, 10:31 PM | #6 |
Yup. my brake light buggerd up for my MOT. he passed me anyway though. only took 30 seconds to fit a new one
31-07-05, 11:57 PM | #7 |
I've never liked these generic switches that every manufacturer seems to use. I may swop for banjo bolt with integral switch. About £20 each I think.
31-07-05, 11:59 PM | #8 |
I'm delighted with the generic- I was a bit concerned about how I was going to wire up the new master cylinder, and it turned out it took the standard SV switch. Lovely. I doubt there'd be space for a pressure switch since the banjo sticks out directly downwards. (aside: How clever is that? Completely removes the high-spot that the stock m/c has, as well as looking very neat)
01-08-05, 04:21 PM | #9 | |
Re: Front Brake Switch - is it me??
K6 compatible Front brake switch | Baph | Stuff Wanted | 3 | 12-02-09 11:12 PM |
Front brake light switch | svrash | Stuff Wanted | 0 | 21-03-07 11:01 AM |
FRONT BRAKE SWITCH, 99 CURVY | Well Oiled | Stuff Wanted | 1 | 07-06-06 01:10 PM |
Front brake switch? | Bikerz | SV Talk, Tuning & Tweaking | 4 | 18-05-05 07:52 AM |
Front level brake light switch? | Bikerz | SV Talk, Tuning & Tweaking | 3 | 16-05-05 07:30 PM |
