Old 25-06-16, 03:10 PM   #141
NTECUK
NTECUK's Avatar
Default Re: the PC Gaming thread
Son bough Doom.
Unfortunately the mobo is a bit lacking
So need to up grade from the old AMD Bulldozer to something else....
Old 26-06-16, 12:37 AM   #142
kaivalagi
Trouble is with that upgrade it's likely the mobo, ram and cpu.....you could go for an skylake i5 with 16gb 2133MHz ddr4 ram to save a bit, but put it into a decent mobo so you can get better CPU and Ram later if wanted (I have an ASUS Z170-A and can't really complain, loads of features for the price)
Mark
Triumph and Suzuki owner
Old 26-06-16, 07:13 PM   #143
NTECUK
NTECUK's Avatar
Was looking at MOBO combo up grade's and bare bones like this,
http://www.novatech.co.uk/barebonebu...bb-63008f.html
Old 26-06-16, 09:06 PM   #144
kaivalagi
Do you need a new case and PSU?
There are motherboard bundles out there....could have got a very decent bundle with water cooler and doom for £380: https://www.scan.co.uk/products/asus...v-v2-aio-water
Mark
Old 26-06-16, 09:22 PM   #145
NTECUK
NTECUK's Avatar
Well case not a deal breaker.
PSU 9month old a corsair's semi modular PSU so that is fine
So yes a mob and new faster ram and CPU is the main thing.
Old 26-06-16, 11:23 PM   #146
kaivalagi
The above is providing an up-to-date 1151 socket mobo which can be upgraded against over the next few years, the price might seem a little steep when compared against some options but it's a good compromise for future upgrades.
The next alternative is going with the previous generation 1150 socket mobo supporting older cpu models and ddr3 memory, it will still perform well today and will be quite a bit cheaper but you'd need another upgraded mobo later on....
Mark
Old 27-06-16, 08:15 AM   #147
NTECUK
NTECUK's Avatar
Um well it's a water cooler system that makes me twitchy.
But then it's not unproven and I guess you can add two GPU coolers for the nvidias.
Old 27-06-16, 12:07 PM   #148
kaivalagi
I have the same water cooler, it's okay, sealed unit....
You still need some cooling fans for the case you put it in, to get air moving for the gpu/memory/other cards etc, I assume the gpu has it's own fans fitted too?
Mark
Old 27-06-16, 05:45 PM   #149
ethariel
ethariel's Avatar
Noooo don't go for that case, look at something a bit better and you will see a huge difference. I dithered around budget cases for years till I finally settled for a Fractal R5, it's a pleasure to work with, totally modular and enough slots for fans/radiators to cool a battleship.
You have a decent enough PSU for a single graphics card setup so no issues there, just hold out for a 1070's before investing in a graphics card, Titan performance for so much less.
For fans always keep a positive pressure in the case (but not too much or you will end up with hot spots. I'm running 2x 140mm front and a 120mm bottom intake with 2x140 exhaust (rear and top) plus the graphics card exhaust. System ambient is rerely higher than the room temperature.
For CPU cooler, a poor Sealed Unit liquid with a small radiator will never work well, a 300mm radiator will be overkill (but thats not bad) although I stuck with a Noctua NHU-14S and that cools my i5 OC'd from 3.9 to 4.6 stable, rarely goes over 65 degrees.
ethariel is offline   Reply With Quote
Old 21-09-16, 12:12 PM   #150
Redmist
Redmist's Avatar
Yes yes yes!!!
YouTube Video
http://www.pegdownracing.com/
Want a Gyrocam for your track / road / racing videos? Gyrocam here!
Bikes: Minitwin SV650 '04. Click me!
SV650 (Now Nekked!) '04. Pictures here!
Redmist is offline   Reply With Quote
PC gaming? femaleacid Idle Banter 96 03-08-12 02:32 PM
More Wii gaming speedplay Idle Banter 12 02-02-11 05:34 PM
The PC gaming thread the_lone_wolf Idle Banter 74 24-03-09 09:04 AM
New gaming rig? MeridiaNx Idle Banter 3 23-07-07 04:52 PM
