Old 25-09-12, 06:27 PM   #1
Chris199
Default Motorbike Sat Navs?
hiya all im looking into purchasing a sat nav for my SV im considering highly to go for the Garmin ZUMO 350LM has anybody got one or used on and if so how is it ? any info would be recommended, also if you have a sat nav what do you have .
Old 25-09-12, 06:38 PM   #2
Tomor
Tomor's Avatar
Default Re: Motorbike Sat Navs
I sometimes use my dads Zumo 550 and it is quite useful. Doesn't seem to realise that some petrol stations in Belgium aren't there anymore so you have to use it carefully and use your common sense sometimes.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 25-09-12, 06:42 PM   #3
Stuuk1
Stuuk1's Avatar
I have a TomTom rider v2. It's great, hasn't failed me yet anyway... touch wood.
Got it for £80 on eBay faulty. Changed the battery and it was as good as new
RIP Reeder 20/07/1988 - 21/03/2012
Stuuk1 is offline   Reply With Quote
Old 25-09-12, 10:01 PM   #4
embee
embee's Avatar
Default Re: Motorbike Sat Navs?
I have the Zumo550. Good users forum at http://www.zumoforums.com/index.php
all the info you want on issues etc. Bear in mind these forums always show all the warts, don't be too put off.
Any satnav is only as good as the database, if you don't update POI (points of interest) files they will be out of date, simple.
I've played with a 660 and it is a significantly better unit than the 550 IMO, the 350 ought to be more along the lines of the 660 in use. Also much more compact shape for pockets.
I've had almost no problems with the 550, does what it says.
Definitely worth getting the lifetime maps (LM) from the start, I haven't updated maps due to cost, and now my 550 is too old to risk paying for new maps when it'll probably die sometime. Often find I'm riding across "fields" especially in France where they build roads at the drop of a hat.
If/when it does I'll just get a new unit with LM.
Old 26-09-12, 05:38 AM   #5
Another vote here for the tomtom rider v2, i use mine a lot, it's done two French trips and it's been flawless.
Old 26-09-12, 06:11 AM   #6
rictus01
rictus01's Avatar
I've used the tom tom rider v2 before, it's alright, I like the sun shield thing, display wise a bit small though, don't like the garmin data base particularly, I've been trying to justify the cost of a bike specific satnav for some time, but I just can't, the Navman setup I currently use (S90i), does it all and that cost me £50 all in and so far I haven't found anything it won't do as well as a bike one costing at least 4 times as much, if pushed I'd have the tom tom over the Garmin as I prefer the data base and routing.
Cheers Mark.
Old 26-09-12, 08:59 AM   #7
Mark_h
Mark_h's Avatar
Rictus,
How do you get audio out of the cheepie Navman? I've using an old route 66 with a headphone socket wired into my autocom stuff but most of the car ones seem to have done away with audio ports and all the bike ones are bluetooth only.
Minister for Sustainability
Old 26-09-12, 09:12 AM   #8
Geodude
Geodude's Avatar
Tomtom one v1 (first one they made) has headphone socket and are cheap on ebay but are getting harder to find.
Old 26-09-12, 09:31 AM   #9
Cymraeg_Atodeg
I got a Zumo 550 on the Thou', got the full handlebar attachment kit from Touratech for it too.
Map in it is getting a bit old now, so, should update it, but, never let me down, is bluetooth compatable and can fit an SD card in the bottom and play music on it too. It cuts the music, tells you the information you need then plays the music again, simples.
Work really well with gloves on too
Old 26-09-12, 09:40 AM   #10
_Stretchie_
Large Member
_Stretchie_'s Avatar
I love my 550, it got us all around the AR10 route and the reccys for it.
How to amuze an idiot:
Look right-> <-Look Left
Car Sat Navs - any recommendations? The Idle Biker Idle Banter 15 24-09-12 07:12 PM
sat navs svshaz Bikes - Talk & Issues 0 20-10-10 12:53 AM
What are the advantages of motorbike specific sat navs? monkey Bikes - Talk & Issues 16 03-02-08 03:49 PM
sat navs colinsv25 Idle Banter 8 28-11-07 04:54 PM
Sat Navs pencil shavings Bikes - Talk & Issues 9 10-06-07 02:31 PM
