Old 06-12-07, 12:08 PM   #1
glade
glade's Avatar
Default GPS data logger (skiing, trackdays etc)
Last year i tried to buy a Navman ski tool off ebay but when it arrived it didn't work.
Today I found this...
Ski-log for £99. (demo video here)
Which appears to be this GPS datalogger on ebay with a different logo.The ski-log product also appears to have a UI designed specifically for skiing and easy interface with google earth.
I went a bit mad last night and bought the ebay datalogger.
I have already found some aviation websites and a gps visualiser that can create tracks in google earth, but software suited to skiing/trackdays would be better.
Anyone got any experience with GPS datalogging?
Any good software I could use with it?
glade is offline   Reply With Quote
Old 06-12-07, 12:20 PM   #2
the white rabbit
Default Re: GPS data logger (skiing, trackdays etc)
I just use my 2610 or eTrex as a logger more than anything else. The Garmin software interfaces with Google Earth. I am not certain you can overlay logs on normal Earth without subscribing, unless the logger comes with software. Having said that progs like GPSBabel can often convert logs into formats that might. I can overlay on Arquet mapping, Memory Map and G Earth but there is sometimes a bit of jiggery pokery. What format does in log in?
Old 06-12-07, 12:56 PM   #3
glade
glade's Avatar
Don't know what format, but i definately need to find out... I assume it will just give a CSV file.
I've found a site that does FREE software for track analysis. Looks pretty good in their marketing bumph. Question is if i can import the data from this datalogger.
http://www.race-technology.com/main_...ware_2_37.html
Old 06-12-07, 01:13 PM   #4
the white rabbit
Default: GGA, GSA, GSV, RMC; Optional: VTG, GLL need to look and see what will handle those I suppose. Or does it export in other formats?
Old 06-12-07, 02:36 PM   #5
glade
glade's Avatar
i wasn't sure if that was an output from the gps sensor, not the data logger?
Old 06-12-07, 06:32 PM   #6
the white rabbit
Do GPSW do this one? If so look at the specs on there I would before I buy on ebay. In fact they may do loggers for not much more.
Old 16-12-07, 09:59 PM   #7
glade
glade's Avatar
I got the GPS datalogger last week... seems pretty good. certainly gets an accurate track.
Here is a track of me driving accross town. Its bang on all of the roads in google earth.
Track accross town
Using excel i can chart height and speed etc. Everything that the £100 ski software does really.
I'm pretty pleased that I have saved a bit of cash and that I can get the unit to do what I want... the unit is even sensitive enough to work inside my factory... Time and motion studies might get interesting
Old 16-12-07, 10:07 PM   #8
arenalife
Do these devices and software compensate for height as well as distance? If it doesn't factor in height changes they can't be very accurate.
For example, if you skied 1.4 linear miles down a 45 degree slope, as the crow flies that would only appear to be 1 mile, giving you a lower speed reading.
Old 17-12-07, 09:58 AM   #9
glade
glade's Avatar
it logs height above sea level, so I assume so.
Old 17-12-07, 03:15 PM   #10
gettin2dizzy
Might seem like a silly question. But why on earth would you want to log your skiing? Can't you look at a piste guide?
Anyone off boarding/skiing this weekend? rubberduckofdeath Idle Banter 9 26-02-09 05:36 PM
GPS data logger as a lap timer Zombie Jesus Idle Banter 0 19-08-08 04:20 PM
Snow Skiing.. Daimo Idle Banter 28 14-11-07 05:01 PM
Does anyone have a data tool s1 red??? John 675 SV Talk, Tuning & Tweaking 14 04-03-07 09:01 PM
.org Skiing/Boarding/Blading holiday? Blue_SV650S Idle Banter 6 26-01-07 05:12 PM
