Old 22-12-07, 10:44 PM   #1
viva_unix
Question is it correct oil?
Hi!
I have bought oil for my SV650S to change it in spring. The oil is Klotz 10W/40 Synthetic Engine Lubricant. Looks like it is what I need. The only thing that makes me suspiciouse is the color of the oil. The color is red. Is it any difference in oil because of the color? Is it right oil? Is it good oil?
Thank you!
Old 22-12-07, 11:43 PM   #2
Default Re: is it correct oil?
Sounds fine.
Check for SF or SG rating if you're being an@l about it
Old 23-12-07, 12:40 AM   #3
viva_unix
What is SF or SG? How to check it?
I have rided motorcycle where I need to put oil inside the gas tank. I have no idea of how to do it here.
Old 23-12-07, 12:45 AM   #4
Engine's where the oil is in the gas tank are 2 strokes, they burn their oil along with the fuel.
The SV is a 4 stroke engine, which means its oil is in the sump at the bottom of the engine.
You open a drain plug underneath the engine, let the old stuff drain, then add new through the cap on the left hand side casing.
You'll need 2.3 liters of oil.
Old 23-12-07, 12:46 AM   #5
rictus01
rictus01's Avatar
No it's fine Klotz 10W/40 is fully synthetic bike racing oil, if anything it's to good and could be argued you don't need anything better than semi- synthentic, but it won't do any harm.
Cheers Mark.
Old 23-12-07, 12:50 AM   #6
Lozzo
Umm, point of order, sir. The filler cap is on the right engine cover, not the left.
Old 23-12-07, 12:50 AM   #7
Drinking and technical advice, maybe I shouldn't mix the two.
Old 23-12-07, 10:22 AM   #8
Stig
Well that would depend on if he rides his bike the right way round now wouldn't it.
Old 23-12-07, 10:34 AM   #9
Lozzo
He'd have been at the pop again if he did that, and I can't condone drink driving.
Old 23-12-07, 11:45 AM   #10
Well Oiled
SF and SG are indications of the oil quality, as defined by API (American Petroleum Institute). The S stands for Spark ignition (petrol engine). There are 'C' specifications for Compression ignition (diesel). Somewhere on the can will be a list of specifications that the oil meets.
The F and G are the quality level. Each time the spec is revised and improved it goes up a letter, so SG is a more recent and higher performance spec than SF, but they are both old specs. The latest is SM. If the second letter on your can is higher than G it will be fine as the later specs cover the requirements of the earlier ones.
Hope that helps Keith
Do i have the correct battery? andyfordceo SV Talk, Tuning & Tweaking 3 01-11-08 12:13 PM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
The correct way to filter... caines Bikes - Talk & Issues 15 30-11-05 09:44 PM
