Old 01-11-08, 12:39 AM   #1
andyfordceo
Default Do i have the correct battery?
I have just purchased a sv650s 1999. I got it from a friend and i know it has had charging problems. However the recitifer has been replaced and everything sees ok.
Currently i cannot check the charging system properly as it not insured at the moment.
I just have a quick question the battery model does not match the one specified in the manual. Could this have caused the issue?
Th Battery says - CTx14-BS
Part Number 712140.
I a going to investigate the problem this weekend when i do some maintenance.
Any help would be much appreciated!!
Old 01-11-08, 07:19 AM   #2
hovis
Default Re: Do i have the correct battery?
YT12A-BS
is what most peeps go for
Old 01-11-08, 11:05 AM   #3
maultin
I have a Yuasa YTZ12S.
Fitted for me by the (Honda) dealer that I bought the bike from.
Old 01-11-08, 12:13 PM   #4
ThEGr33k
Sounds like you have a battery more heavy duty than you maybe need. So it should be fine!
is it correct oil? viva_unix SV Talk, Tuning & Tweaking 10 23-12-07 05:41 PM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
The correct way to filter... caines Bikes - Talk & Issues 15 30-11-05 09:44 PM
