Old 18-01-08, 05:57 PM   #1
Soprano69
Red face Engine timing, advice needed please ?
I wondered if someone can enlighten me with some technical info with regard to the above ?
I've recently stripped the top end of a curvy engine to give it a once over and grind the valves etc. I'm now ready to put the thing back together.
As its the first time I've done this, I've been following the letter of my haynes manual but, unless I've missed something, it seems to me there is a gap in the info supplied in the book.
When you align the timing mark on the flywheel to Tdc, how do you know if its on the ignition stroke or the exhaust stroke if the camshafts have been removed ? I think I should have probably marked the camchain before removing the shafts, or done one cyl at a time, but it didn't occurr to me till later.
I know the valve timing is determined by where you set it when the camshafts are re-fitted and I don't have a prob with that but is it possible to get the ignition 360 degrees out and hence firing on the exhaust stroke ?
I'm probably missing something really obvious here and about to be ridiculed for being a numpty but can someone put me out of my misery ? I need to get it reassembled now, I want my dining table back !
Old 18-01-08, 06:31 PM   #2
Default Re: Engine timing, advice needed please ?
The haynes manual seems somewhat limited on a lot of info. ....have you ever thought of a 'Clymer manual'.....its a lot more informative. you can buy them off ebay quite frequently.
I can't help you with your question, I'm afraid, but the Clymer is better IMO. I have both
Old 18-01-08, 07:45 PM   #3
charlie13
There are some manuals that you can view from the www.sv650.org page, but I can't seem to get on it right now to view them. I've got workshop manuals for both pointy and curvy in pdf format. The files are quite large but I can split it down and mail you the relevant sections if you can't find them anywhere else.
Edit
ps - have you tried a search on "engine timing" or "cam timing" or similar, sure I read something a while back that had some good advice of checks to do before you hit the starter button.
Old 18-01-08, 09:10 PM   #4
Well, I've never done this so please bear in mind I could be talking ****e...
The cylinders are 90 degrees apart, so if you know the firing order then you can work it out from that I think.
Is front first or rear? If you got it wrong, does the engine waste spark? if this would run, would it damage it?
Old 20-01-08, 05:46 PM   #5
Soprano69
Chris, this is my question, does the engine spark on both strokes anyway, in which case it wouldn't matter but I can't find any reference to this.
Old 20-01-08, 06:08 PM   #6
This is the wasted spark I refer to.
The black box gets triggered at crank speed, so correct me if I'm wrong but it can't actually tell whether its on compression or exhaust.
However like I say I'm really just speculating, I've never done this job.
P.s northwind is probably the man to ask
Old 20-01-08, 06:35 PM   #7
jamesobrady
The position of the cams tells you what stroke your engine is being set up to
Old 20-01-08, 06:38 PM   #8
You can figure that out, but how do you know whether you're on compression or exhaust when the cams are out?
Old 21-01-08, 12:21 AM   #9
zadar
if cams are out there is no compression or exhaust stroke,just stroke.
when you put cams in you basically tell engine which stroke is what.
in other words it does not matter,you can start anywhere you want,front or rear,any crank revolution.you just make sure where ever you start next cylinder is one crank revolution apart and both cylinder cams are set at F mark(not R for rear).R is TDC but not where you set cams at.cams are set at F mark for both cylinders(one revolution apart).R mark is only to check valve clearance.
Old 21-01-08, 12:24 AM   #10
Advice needed regarding engine temperature rowdy SV Talk, Tuning & Tweaking 10 13-01-09 04:26 PM
650SK3 engine unit needed TeddyBearKing Stuff Wanted 18 23-06-08 05:46 PM
Engine paint - help needed 5hort5 Bikes - Talk & Issues 8 17-02-08 03:55 PM
Advice needed - Engine trouble sickboygti SV Talk, Tuning & Tweaking 12 17-09-07 04:27 PM
Engine gasket needed spamrot Stuff Wanted 0 19-12-06 02:16 PM
