Old 24-02-08, 12:41 PM   #1
John 675
Default rearset replacement
im getting som GB moto sets at the end of this month
but how easy is it to fit rear sets???
Old 24-02-08, 01:34 PM   #2
Rich
Rich's Avatar
Default Re: rearset replacement
Piece of cake you'll be fine, do they keep the original rear brake light switch? If not you can get bango nuts that include a presure sensor to get over this.
RIP Hovis - Unlucky Boyo
Old 24-02-08, 02:31 PM   #3
petevtwin650
Almost certainly you'll not get the pressure switch in the kit. Check though.
You will need one as no rear brake light is an MOT failure. Also make sure you get a banjo bolt one with the correct thread. Sorry can't remember the size.
I was lucky with the Switch I bought off of ebay. The leads plugged into the OEM plug under the riders seat. Saved having to splice wires together.
Old 24-02-08, 03:33 PM   #4
Yep, it's basically easy apart from that one fiddly detail. I can't remember what size the banjo is either but an reputable seller would be able to tell you.
Old 24-02-08, 05:02 PM   #5
Dangerous Dave
Its a very simple job, you will need a single pressure switch Banjo bolt though if the rearsets don't come with the provision to use the OEM spring for the rear brake light.
Old 24-02-08, 05:05 PM   #6
flymo
flymo's Avatar
I've just fitted diamond race rearsets which are really nice quality. I did find though that the rear brake reservoir no longer reaches the mounting point so I had to sort that out. No need for brake switch on a race bike so didnt bother on that one
Old 24-02-08, 08:16 PM   #7
Red Herring
Red Herring's Avatar
Don't think the rear brake light switch is an MOT requirement, as long as it works on one of the brakes. Three of my bikes only have the brake light working on one brake (two on the front brake, one on the rear only) but it might be that the guy who does my MOT's is just a good egg. If anyone out there knows the rule book for sure I'd be interested to know.......
Old 24-02-08, 08:30 PM   #8
Lissa
Just Ballast
Lissa's Avatar
Well, from what I can figure out from this link, all bikes registered after 1st April 1986 must have a brake light that works from both front and rear levers.
http://www.ukmot.com/bike_1-3.asp#Text_top
Old 24-02-08, 08:41 PM   #9
Red Herring
Yes, I'd go along with that. Guess he's a good egg then. Thanks.
Old 25-02-08, 01:55 AM   #10
Dangerous Dave
Yeap, thats right!
Looking for: LHS Rearset - 99 Curvy JimmyGulp Stuff Wanted 6 04-07-08 03:41 PM
Rearset bracket plowsie Stuff Wanted 4 03-07-08 10:43 AM
rearset Compatability andyb SV Talk, Tuning & Tweaking 25 27-09-07 07:41 PM
I designed some rearset for SV r4ce_e3nd SV Talk, Tuning & Tweaking 16 10-11-06 09:59 AM
Rearset fitting rigor SV Talk, Tuning & Tweaking 4 11-12-05 05:24 PM
