Old 10-12-05, 06:03 PM   #1
rigor
Default Rearset fitting
After my off, I've (finally) got all the bits to fix my bike.
I decided that a broken rear brake pedal necessitated some Gilles rearsets :P It was on my list of things to get anyway, just brought forward by about 6 months
Anyway, after looking at the instructions, I just wanted to make sure that I'm going to fit them OK. The german translation on the sheet isn't brilliant, so basically I'm asking, is there anything I should look out for? Or does anyone have a link to a page where there are slightly better instructions?
Ta.
Old 10-12-05, 06:07 PM   #2
Scoobs
Take some photos of the current footrests from all angles and use this as a reference.
It won't be hard to change them out. They'll go together better than the original monkey metal ones as well.
Old 10-12-05, 06:17 PM   #3
Carsick
watch out for pinging springs and make sure you setup your rear brake light switch properly. Also make sure you adjust the gear shift rod properly so the gears change nicely.
Old 11-12-05, 11:53 AM   #4
John Burt
I'd use a bit of loctite on the mounting bolots as well!
Old 11-12-05, 05:24 PM   #5
21QUEST
21QUEST's Avatar
Just to add to that , I'll loctite(blue) every bolt that may become undone. ie main mouning bolts , foot pegs bolts and I even put a a bit on the locknut on the shift rod. Basically if it's likely to be an ugly situation if it comes undone it gets the blue loctite treatment.
Ben
Nemo me impune lacessit.
rearset replacement John 675 SV Talk, Tuning & Tweaking 44 01-05-09 08:32 PM
Looking for: LHS Rearset - 99 Curvy JimmyGulp Stuff Wanted 6 04-07-08 03:41 PM
rearset Compatability andyb SV Talk, Tuning & Tweaking 25 27-09-07 07:41 PM
I designed some rearset for SV r4ce_e3nd SV Talk, Tuning & Tweaking 16 10-11-06 09:59 AM
Rearset on eBay Chris SV Talk, Tuning & Tweaking 7 28-04-06 04:29 PM
