Old 23-03-08, 01:31 PM   #1
andyb
Default Shock spring change
Do you have to have a spring compressor to change the spring on the rear shock or can it be done by other means like ratchet straps etc? Going ot be changing mine soon (on another bike) and don't fancy paying out for a tool I'm only going to be using once and I would quite like to do the whole job myself!
Old 23-03-08, 01:44 PM   #2
21QUEST
21QUEST's Avatar
Default Re: Shock spring change
What bike is it Andy?
On the OE shocks with step-less adjustment, you should be able to just unwind the preload adjusters all the way out, lift springs and slip out the bottom spring seat. The spring can now be removed. There amy or may not be may a circlip you have to remove before the seat can be taken out.
Ben
Nemo me impune lacessit.
Old 23-03-08, 03:51 PM   #3
andyb
It's on the ZX6R. I don't think you can wind out the preload adjusters on this one (or so they say on mcnninjas) but I think I remember someone on here saying you can use ratchet tie-down straps to compress the spring and do it that way???
Fork Spring Change - Tools chasey SV Talk, Tuning & Tweaking 11 27-04-09 05:43 PM
Price for fork spring/oil change glade SV Talk, Tuning & Tweaking 14 06-09-08 08:01 AM
front spring oil change etc jon8oy SV Talk, Tuning & Tweaking 7 18-12-07 06:31 PM
Shock spring replacement... Gnome SV Talk, Tuning & Tweaking 5 30-06-07 05:55 PM
Folk Spring and oil Change Samurai SV Talk, Tuning & Tweaking 23 31-03-06 04:55 PM
