Old 30-04-08, 06:38 PM   #1
stevehaskew
Default Unhappy clutch
Very unhappy, in fact. I was just going round Hammersmith Broadway and halfway through a change from 1st to 2nd and there was a bad noise and I lost power. Having pushed the bike back to work I decided to investigate. I discovered that my chain had broken the clutch pushrod and come off the sprockets. So... the AA are going to relay me home, but how much effort is it going to be to get this fixed? Or, more to the point, how much will it cost me to get someone else to do it?
Can the pushrod be replaced easily? Or will it be lots of expensive parts?
I've got nothing better to do until the AA turn up, so I'll go and keep poking around.
Old 30-04-08, 10:23 PM   #2
Default Re: Unhappy clutch
Depends what else it's broken.
What have you (not) been doing to the chain!
Old 30-04-08, 10:53 PM   #3
zadar
push rod is easy to replace.pull it out and put new one in.
you should replace seal also.
Old 30-04-08, 11:03 PM   #4
stevehaskew
Looks like it's just that which is broken. The chain is nearly worn out, I've recently been getting around to planning to get it and the sprockets done. Unfortunately with the chain, on two consecutive days I said to myself "Ooh, that needs adjusting" as I set off and then completely forgotten by the time I get home
Lesson learned! Going to try and replace the pushrod myself and then do the chain and sprockets before I ride it again. Until then, I'm driving into work
Old 06-05-08, 05:38 PM   #5
stevehaskew
Just in case it helps anyone, the repairs for this were pretty cheap. Rod replaced, chain and sprockets replaced, all for £137.92 inc labour.
Crash.NET - Unhappy Elias gets 'tyred' - again. NewsBot News 0 17-10-08 09:50 AM
Crash.NET - Pramac unhappy with JiR statement. NewsBot News 0 27-09-08 05:41 AM
Unhappy thoughts thread hovis Idle Banter 43 10-09-07 02:48 PM
Unhappy engine? seandixie SV Talk, Tuning & Tweaking 15 03-02-07 09:53 PM
One VERY unhappy Ping. Ping The Essex Lounge 8 22-02-05 09:41 AM
