Old 04-05-08, 04:29 PM   #1
a1istair
Default Hazards on a Curvy
Hi
I am doing some wiring on my bike, fitting cigar socket / autocom, and was wondering if it was worth while somehow installing a hazard flasher switch.
Has anyone done this? Is it a good idea? Do you think it would be quite easy to do?
Cheers,
a1istair
P.S. 2001 Naked Curvy
Old 04-05-08, 04:52 PM   #2
Dangerous Dave
Default Re: Hazards on a Curvy
Never had the need or feeling too but it can be done, rig it up to a toggle switch.
Old 04-05-08, 08:25 PM   #3
scottjames
the alarm i have has an extra button that gives you hazard lights but ive never used it.
Old 05-05-08, 02:37 PM   #4
Baph
Never done it (I made the right choice & own a pointy). But it should be pretty easy.
In theory (from a quick look at the wiring diagram)...
There are 3 wires in the indicator switch. One comes from the relay to control timing (on-off cycles), the other two go to the indicators. So the thinking is that you just connect BOTH these two wires to the one that comes from the relay (using a switch).
Heypresto, hazard lights.
Old 05-05-08, 02:42 PM   #5
Yup but have to use a 4 contact switch or some diodes, otherwise it will become a path for current and using indicators normally will make all 4 flash.
Old 05-05-08, 03:20 PM   #6
Baph
Just a bog standard DPST (such as a Dual on-off) switch will prevent that. That way, the indicators are only joined to the relay when the switch is in the 'on' state.
Old 05-05-08, 03:21 PM   #7
Thats the one's I'm thinking of
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
Hazards won't turn off/Meta Alarm sparkymarky SV Talk, Tuning & Tweaking 3 14-03-07 04:48 PM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
