Old 07-05-08, 11:08 PM   #1
Default Northwind's lever clearance sale!
I finally got up the motivation to clear out all my levers. There's quite a few These are in varying condition but they'll all be usable, any that weren't are now in the bin. All are genuine Suzuki unless stated otherwise (as far as I know at lesat)
They are as follows:
Number 1 is straight and in good condition, it came off my bike when I fitted rearsets, otherwise it'd still be on there. If memory serves these are about ?40 new, so I'll take ?25 for it delivered in the UK SOLD TO SHELL
Number 2 is ground down at the tip but works perfectly, I scraped this down nicely at knockhill but I just carried on using it for ages out of laziness, it'd make an ideal spare, or you could just use it like I did. ?10 delivered for this one. SOLD TO COLBY
These are all curvy model gear levers in various states of repair.
3 is in good condition apart from the obvious, it doesn't have a toe piece- I drilled it out and used a bolt and some rubber in its place, which worked very well. What you get here is just the lever though. It also has a weird scrape across just above the rubber boot, and a matching scrape on the rubber boot. It's still servicable though, and a little work to give it a toe piece would give you a perfectly good spare. ?5 SOLD TO DIRTYDOG
4 is in reasonable overall shape, it has a couple of minor scrapes and the . The bushing in it is a bit worn, about average for a used part. This one was on the bike til I fitted my Valter Motos and I believe works just fine. Again, I think these are ?40 new so I'll do this one for ?15 SOLD TO DIZZYBLONDE
5 is in perfect working condition... But, it had the tip snapped off. I've done a (very nice) repair on it using a tapped-in and threadlocked M8 bolt, as you can see in the pic it really looks as good as new and it works perfectly. the bushing is worn down, so it's slightly loose but works fine. The lever is overall a little shorter than standard, but that shouldn't matter. Again, ?15, given the repaired damage
These are carbed model front brake levers- I think, I don't have a standard perch to compare with but I'm as sure as I can be that this is what they are.
6 is obviously a pattern part. It's in decent nick, it'll work perfectly but the anodising on these is poor so it's got a few scrapes. This is another piece that I was using til I upgraded, I'd still be using it otherwise I reckon. Fiver for this one, they're cheap new. SOLD TO GRINCH
7 is an OEM lever, and has a slight bend in the tip and a scrape on the ball. It's entirely functional though, works perfectly. ?10 for this, given the small amount of damage. SOLD TO TIMINBELGIUM
OK, I don't know what these are They look just like SV clutch levers, but the mount with them isn't quite the same. Again, I've got no SV perch to compare them against. The levers are all in good shape. The perch is worn but straight, and will definately work with the SV- I've had it on mine. I think these levers will probably fit the SV clutch perch as a direct replacement, but I can't guarantee that so they're cheap, £10 for 2 and I'll chuck in the perch so no matter what you'll be able to get them to work. (one of these is now gone)
These are SRAD clutch levers and perches. The levers are both uncrashed, but one has had the part that would push against the clutch switch ground off (so you'll have to bypass the clutch switch). The perches are in good shape. The pair of these- levers and perches- are ?15.
I'm not really open to offers on any of these, since the prices are already low, I just want to pass them on or get rid of 'em really No point in even posting them out for much less than this. i'll combine postage though, knock off a quid for each subsequent item. I can't really guarantee that any of these is exactly what I think it is, so with the exception of number 8, if I'm wrong I'll give you a full refund of course.
Old 07-05-08, 11:13 PM   #2
maultin
Default Re: Northwind's lever clearance sale!
blimey - thats some advert. mondo brownie points for thoroughness
Old 07-05-08, 11:25 PM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
How many levers?
AH!... AH!... AAAAH!...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 07-05-08, 11:28 PM   #4
Fair to say I was quite surprised There were another 5 or 6 that went in the bin. I've aquired quite a few bolted to other bits or in job lots.
Old 08-05-08, 07:30 AM   #5
SoulKiss
SoulKiss's Avatar
Well DizzyBlonde is looking for a lever - gear I think it is - might be worth a PM to her Northy
█╬╬╬╬(•)iŻi▀▀▀▀▀█Ξ███████████████████████████████)
Old 08-05-08, 07:47 AM   #6
Grinch
I'm looking for leavers, though I can't see any pics at the moment so will have to check it out later.
Old 08-05-08, 07:58 AM   #7
dirtydog
Knob faced knobster
dirtydog's Avatar
I'll take lever #3 from you Northy
2011 Speed Triple 1050
Old 08-05-08, 09:47 AM   #8
Shell!
Can i have first dibs on lever #1 please?
Old 08-05-08, 12:49 PM   #9
1 and 3 claimed by DD and Shell! (number one is the best of the lot btw )
Old 08-05-08, 01:14 PM   #10
MR Northwind, would like to have one of your gear selector levers as my thing has no bushin left in it and its awful on the foot and flaps about with the rod. No4? Would you be so kind to sell me one of yours so I can change gear properly...mmm and a clutch lever would be nice too, the other bikes got one very wobbly. Ta PM me purleeez
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Curvy clearout clearance sale... Razor For Sale - SV's and SV related items 10 19-07-07 09:04 PM
YZF RI front brake lever for sale John 675 Idle Banter 0 10-05-07 10:33 AM
Northwind's Annual Hip Armour Rant... northwind Bikes - Talk & Issues 15 05-09-06 01:26 PM
