Old 22-06-08, 08:17 PM   #1
The Laughing Assassin
Smile jumping out of 2nd :-(
Stupid bike............ Why does it keep jumping out of 2nd gear????
It only does it on clutchless changes, mainly when changing 1st - 2nd on the back wheel (most junctions) and it is really starting to P*ss me off
any ideas?
Thanks
Old 22-06-08, 09:35 PM   #2
21QUEST
21QUEST's Avatar
Default Re: jumping out of 2nd :-(
Checked your chain free play ?
Ben
Nemo me impune lacessit.
Old 22-06-08, 09:39 PM   #3
Side MS
Mine sometimes does this but thought it woz due to me trying to change up to quick and not given the bike time to fully engage into second gear. Got no technical reason for it but it seems to be ok if i flick the gear shifter up harder.
Old 22-06-08, 10:05 PM   #4
21QUEST
21QUEST's Avatar
Forgot to say , also check that the gear change linkage where it bolts to output shaft is torqued up properly. If it's not, it can cause missed changes/what side MS mentioned to happen. Also will cause wear on the splines....which is not good.
So basically I'd be check chain free play, what I siad above and that the gear lever moves as it should. It could of course, be non of the above(but hopefully it is one of the above ). I just like to start off with the KISS principle
Ben
Old 22-06-08, 10:43 PM   #5
St0rmer66
I'd have thought it would be pretty normal to do this kind of thing doing a clutch-less up-shift from first to second, given that neutral is between them. It's the reason I don't do clutch-less changes from first gear myself as I can rarely get it right (might just be me I suppose...).
Old 23-06-08, 11:16 AM   #6
chain and gear lever are both ok...... Have tried using the clutch but the front wheel falls out the sky!!!
It may just be that it don,t like cluthless changes 1st - 2nd
Old 23-06-08, 11:21 AM   #7
21QUEST
21QUEST's Avatar
Why are you wasting time/effort and risking gear box problems getting it up in first?
The Sv will come up(easily) in second gear from as little as 10mph or so
Ben
Old 23-06-08, 11:21 AM   #8
Dangerous Dave
Technique Error!!!
Old 23-06-08, 09:03 PM   #9
have tried various techniques and it still does it......... I WILL have a go at gettin it up in 2nd and go from there. But i do like to get it up from a standstill and go thru the gears.......
Old 23-06-08, 09:27 PM   #10
St0rmer66
I thought wheelieing an SV650 was bad for it anyway? It's a wet sump so all the oil will just go to the back of the engine and starve the front cylinder. Eventually meaning grinding noises, a crunch and new engine time...
jumping out of gear AndyBrad SV Talk, Tuning & Tweaking 15 12-05-09 09:47 PM
Bike keeps jumping out of 2nd gear. jimmy-james Bikes - Talk & Issues 23 25-04-09 11:13 PM
red light jumping cyclist.... Spiderman Idle Banter 40 15-07-08 04:40 PM
Cliff jumping! ClemsonSV Idle Banter 7 25-07-07 02:23 PM
Nutty Tart jumping out a plane - who will pay to help this? Anonymous Idle Banter 86 05-08-06 06:10 PM
