Old 26-08-08, 07:33 PM   #1
Cyclops
Default Tipping in and tracking
Fitted Hagon springs to front and kwak suspension to rear last year.
Since then my bike when I go round corners/junctions/roundabouts at slow speed the bike really wants to 'tip in'.
Is this just the result of better suspension?
Also tracks more when i go over cracks in road, edges of road repairs, etc.
Have done approx 6K miles since bought it last year and rear is starting to square off but would that make the front tip in?
Any thoughts would be appreciated - give me something to work on this weekend.
cheers
Old 26-08-08, 07:39 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Tipping in and tracking
I always found that squared off tyres made it intially reluctant to steer and then all of a sudden it would tip in very quickly so if thats what you're feeling then it might be your tyres are squared off, that would certainly IMHO tie up with the bike tracking oddly over rough surfaces.
Old 26-08-08, 08:45 PM   #3
The kwak shocks are a little longer than standard, could be you're just feeling the results of more aggressive geometry?
Old 26-08-08, 08:54 PM   #4
Cyclops
Could just be better suspension. Stiffer front and higher rear giving that impression of tipping in more sharply.
I was just wondering if anyone recognised symptoms and immediatelly would say " Aha, thats XYZ etc."
Never having ridden anything alse I don't have a benchmark.
Old 26-08-08, 09:00 PM   #5
flymo
flymo's Avatar
I learnt a rather stupid lesson with mine.....have you checked the front tyre pressure? I had a faulty front tyre valve that kept leaking and the bike felt like it was going to tip over when I tried to turn.
Old 26-08-08, 09:06 PM   #6
Cyclops
Pretty sure its Ok, but now you've mentioned it you know I've got to check it!
Old 27-08-08, 06:02 AM   #7
lukemillar
This is what I would say is the answer. Can you measure the the trail on the bike and then compare it to the standard trail on a curvy?
Old 27-08-08, 07:28 AM   #8
Biker Biggles
Biker Biggles's Avatar
I would say tyres.Worn tyres cause handling to go off.Most dont notice until a new set go on.
Old 27-08-08, 07:49 AM   #9
flymo
flymo's Avatar
Are the fork tubes in the normal position or are yokes dropped down over them? If normal then the fork tops should be near enough level with the top of the top yoke.
If they've been dropped significantly it will add to the problem especially with a longer rear shock.
Tracking Santa Lissa Idle Banter 1 19-12-07 05:48 PM
sv 650 tipping in leemole SV Talk, Tuning & Tweaking 22 07-08-07 04:58 PM
It's tipping it down in Manchester... El Saxo Pennine Massive 21 15-06-07 12:54 PM
Find anyone, anywhere. GPS tracking. Razor Idle Banter 4 05-05-07 09:51 PM
Tracking Santa. admin Idle Banter 6 24-12-06 11:15 PM
