Old 28-08-08, 08:34 PM   #1
svrich
Default Wrung a bolt off!
Sodding engine bolt (upper left side) wrung off as I was re-torquing it after fitting the faring bracket
The Haynes says 55nm and I checked it four times as I was tightening it. The bolt kept turning then popped and sheared off. Fortunately there was 5-6mm sticking out of the engine casing so I removed the spacer, sprayed with loads of WD40 and used a screw/bolt removal bit to wind it out - Phew
Thing is, is the quoted nm correct, and/or was it a dodgy bolt?
I'll be getting a new bolt tomorrow and fitting it in the afternoon so I don't fancy going though all that again.
Is there a particular sequence to refitting - do I loosen the spacer pinch bolt before fitting the bolt?
Old 28-08-08, 09:19 PM   #2
embee
embee's Avatar
Default Re: Wrung a bolt off!
Old 28-08-08, 09:37 PM   #3
svrich
So 55nm is correct then.
Must have been a dodgy bolt - go Suzuki!
Hopefully back on the road tomorrow and a long test ride to check everything works
Cheers embee
This Particular Bolt DarrenSV650S SV Talk, Tuning & Tweaking 8 27-08-08 05:18 AM
Fairing bolt / Mirror bolt MiniMac Stuff Wanted 0 02-07-08 10:26 AM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
Help me build a spare bolt box; what are all the common bolt F16Falcon SV Talk, Tuning & Tweaking 10 07-05-07 08:42 AM
Seat Bolt and bar end bolt Colby Stuff Wanted 3 04-04-07 04:56 PM
