Old 05-09-08, 12:27 PM   #1
riktherider
Default servicing gsxr usd forks.
got a pair of gsxr750 srad forks off of ebay a while back, and while im still waiting for parts thought i would strip them down and service them. managed to get the top tube off, but the damper rod and the bolt at the bottom of the leg (10mm allen key) are not coming out. i tried loosening it before i started stripping them, no luck, so i thought there might have been a way inside to loosen in all up. i cant seem to sort it out. anyone know of an online manual or knwo how to do it??? really cheesing me off at the mo. the bolt just turns.
cheers
Rik
Old 05-09-08, 12:30 PM   #2
Dan
Default Re: servicing gsxr usd forks.
You'll need a special tool to hold the damper rod assembly in place while you undo the bolt through the bottom of the leg, I believe.
When I did the fork seals on my ZX7 I had to buy one off eBay.
Old 05-09-08, 12:33 PM   #3
riktherider
just had a browse on ebay, it looks litke thats the case. hmmmm, might be able to make something which will work.......
Old 05-09-08, 12:40 PM   #4
Dan
Yeah, I thought that... tried all sorts but in the absence of a machine shop at the time, I was left with just buying the damn thing. It's only a bit of tube with a few little cutouts on the ends, and a bar. It fits a variety of fork types including KYB, Ohlins, and Showa, apparently. Was about a tenner.
Old 05-09-08, 12:43 PM   #5
Why do you want to remove damper rod?
Old 05-09-08, 12:57 PM   #6
riktherider
just had a look at the bottom of the fork and its a rather large hexagonal internal tool i need. tried using some spark plug wrenches but i only had one deep enough but it was too small.
im just bored and wanted to give it a good service. make sure everything is in top form.
also how much oil is required in the forks?? i think there was an absence of oil in the forks previously as they were really really spongy. unless they have really soft springs. ive got a load of 15wt oil which i'll try first.
Old 05-09-08, 01:07 PM   #7
I reckon 15 will be too hard, I think I've got 7.5 in my 600 SRAD ones.
Old 05-09-08, 01:33 PM   #8
riktherider
like i said it was really really soft to begin with. its the only oil ive got in the garage, so im not too fussed if i need to buy some more, as its technically free. it could be the old mans, but never mind!!
Old 05-09-08, 01:59 PM   #9
sv650k4
When i done my zx7 forks i never need a special tool.
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
gsxr k6/7 forks maff SV Talk, Tuning & Tweaking 7 10-02-08 06:02 PM
gsxr forks on the sv k3? kwak zzr SV Talk, Tuning & Tweaking 12 11-12-06 11:50 AM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
