Old 21-09-08, 07:21 AM   #1
ThEGr33k
Question Getting sprayed (the bike not me)
Well as many of you probably know I went grass tracking on the bike and have managed to grate some of the nice paintwork off of my bike
Im wondering if I can make it look reasonable without going to a shop? I need to just make it look ok for now... so whats the best way to do it?
I think I will eventually be getting it done properly when I get a chance, so anyidea where there is a good bike spray shop somewhere near Sheffield/Yorkshire?
Old 21-09-08, 08:46 AM   #2
muffles
Default Re: Getting sprayed (the bike not me)
Doh just found your hidden posts in the other thread, at least you seem to have pretty much fixed it up already?! What do you want to do to make it reasonable? You can do some temporary DIY spraying if that's what you mean...can't think of anything else. Me, I'd just spray it in primer and basically get it ready for the shop, so they have less work to do = less time away, less money spent.
Btw not sure if those are stickers on the upper/side fairings but you probs want to remove those if they are, before carrying on, they will want to be off.
Old 21-09-08, 09:12 AM   #3
ThEGr33k
They arnt stickers no... or if they were they were lackered on so arnt removable without some sand paper. I think the fairing will need all the pain removing before I can get a shop to do it right, its very thick in places. The problem I have is the bike is my only transport so I need it to be usable while I sort it
For now yes I want it to just be looking at least ok, so will be sprays I suppose.
Also Im not sure what to do with the colour... I think it looks ok in the silver but im not sure if something else may look better.
Im thining of changing it to the same setup as on the bike in post 12. feel free to have a look through those and see what you think I should paint it like.
Old 21-09-08, 10:13 AM   #4
Dangerous Dave
Yes they are lackered on stickers Gr33k, something the Japanese do not do.
I like that.... overall a professional finish will probably be better if this is going to be your first attempt.
Old 21-09-08, 12:56 PM   #5
muffles
Except on their tanks...
That black lower fairing looks OK, there doesn't seem to be much of a fairing down there anyway so it kinda makes it look like it's meant to be there more (when it stands out, it stands out as being a bit small).
You should be able to remove the paint and stickers and still keep the bike usable, right? Just do it a piece at a time, etc.
Old 21-09-08, 01:06 PM   #6
ThEGr33k
Ive got the belly pan on mine so it looks a little more substantial. Ill need to give that a spray as well so that could be my guiness pig for the spraying of the black.
Ill have to use the crappy looking fairing lower thing that has while I do it. Shouldnt be hard.
Old 21-09-08, 01:23 PM   #7
Dangerous Dave
How would it look with the bellypan painted the same as the top half with the centre section black?
Old 21-09-08, 01:51 PM   #8
ThEGr33k
Interesting question! I dont know... Someone good at photoshop want to have a go? Black middle section (the bit with the fans in) and silver belly pan. Then maybe if you could black from middle down?
Probably not have any takers
Ill have to look into getting some stickers too I guess since I grated two/3 of them. Sigh.
Old 21-09-08, 04:54 PM   #9
sv-robo
Only just seen this,thats a total bummer mate,hope everythings sorted asap.
Old 21-09-08, 05:01 PM   #10
Paul the 6th
Paul the 6th's Avatar
ah is it the black ip/jp logo further down which took a bit of a beating? I'll sort the decals out for ya nick
Recommend somewhere to get a belly pan sprayed? walnuts Guildford Massive 6 07-08-06 06:18 PM
Spraying bits you don't want sprayed... UlsterSV SV Talk, Tuning & Tweaking 7 01-04-06 10:27 AM
getting a helmet re-sprayed. easy? Dirty Baz Helmets 5 26-05-05 07:06 PM
