Old 07-10-08, 02:22 PM   #1
the_elements_600
Default K4 SV650S problem
I've owned my SV for 3 months now and love it, but recently I've encountered a problem. When I'm stopped and go to accellerate, the engine just dies.
I'm sure its not me stalling it by accident as it just dies...it doesnt jolt forward or anything. It's done it with the fuel light off aswell so lack of fuel can't be the answer. The engine has always been at normal temperature too so its not a cold engine. Also its when I'm in traffic, so it's not the sidestand safety feature
Help!!!
Old 07-10-08, 02:26 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: K4 SV650S problem
idle speed set too low? does it just die when you open the throttle?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 07-10-08, 02:32 PM   #3
the_elements_600
Yeah...throttle on a little bit, clutch out as normal and it just dies. It doesn't do it all the time, but it's done it 3-4 times this past month. It idles at around 1000-1200 ish.
Old 07-10-08, 02:40 PM   #4
the_lone_wolf
Captain Awesome
if i remember correctly idle should be 1250 minimum, closer to 1500 or so when warm but i'll have a look in my haynes manual tonight
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 07-10-08, 02:58 PM   #5
the_elements_600
Ok. Thankyou
Old 07-10-08, 03:55 PM   #6
JimmyG
air filter and fuel filter clean etc?
Old 07-10-08, 09:31 PM   #7
phil24_7
Give it more beans when your pulling away. Often stall mine if I'm too lazy on the pull away!
Old 07-10-08, 09:42 PM   #8
sinbad
Not an easy bike to stall though, 1st gear is pretty short and the engine chugs with enough oomph to virtually let you pull away with no throttle input at all if you're gentle with the clutch lever.
I'd say it could be the idle speed, possibly, but I assume it won't cut out if you just go to blip the throttle in the same way with the clutch in or bike in neutral?
Maybe check your clutch lever adjustment. If the biting point has moved closer to the bar you may be engaging the clutch much earlier than you were before, which would make it easier to stall if you didn't notice it.
Old 07-10-08, 11:02 PM   #9
phil24_7
Mine occasionally cuts out when I blip the throttle, again, nothing to worry bout!
Old 07-10-08, 11:15 PM   #10
Stu
Trinity
Stu's Avatar
Often stall mine !
2002 sv650s K&N problem erics02 SV Talk, Tuning & Tweaking 6 18-10-07 09:52 PM
problem wiv tyres on an old sv650s? weemanno1 Bikes - Talk & Issues 4 04-06-07 09:25 AM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
SV650S Problem??? marshms SV Talk, Tuning & Tweaking 13 13-05-05 05:35 PM
