Old 12-05-05, 09:22 PM   #1
marshms
Default SV650S Problem???
Need help! My son was in a minor accident with his 2001 SV650S. Most damage was to fairing, speedo and lights. I've replaced all the entire fairing, speedo unit, handgrips, radiator, left footpeg/assembly, shift lever, front wheel, both tires, battery, etc. Figured I might as well do things right once I started. I started the bike up last week for the first time in 2 months. I noticed that when I rev the bike to around 3000 RPMs that the exhaust down-tubes off the front cylinder gets red hot (glowing red/orange), back tube also but not as much. I don't remember this happening before, but I might just not have noticed. What could the problem be?? The bike seems to be running fine but don't want to damage anything until I get this fixed if needed. I've checked for airleaks around carbs, intake, etc but can't find anything wrong. Do I need to take this to my mechanic or is this normal??
Old 12-05-05, 09:24 PM   #2
TSM
The Sick Man
TSM's Avatar
someone will probably say its because the bike is running either lean or rich (i dont know which one)
Old 12-05-05, 09:26 PM   #3
fizzwheel
fizzwheel's Avatar
its not normal.. they get hot, but shouldnt glow
As for the cause I have no idea, sorry
Old 12-05-05, 09:35 PM   #4
embee
embee's Avatar
I have seen it on the SV before. It shows up more in a garage where there's lower light levels.
There may be something wrong, but I suspect what you're seeing is "normal". It's not nice, but it's the way they are. It's less pronounced if you advance the ignition with a stepped key or slotted pick-up mounts (allegedly! ).
Old 12-05-05, 10:01 PM   #5
Dan_SV
It is normal, someone asked this question a while back.
Dig through using the search function and you should find something.
Dan.
Old 12-05-05, 10:11 PM   #6
Dan_SV
In fact, you muppet, we did answer it a while back. I draw your attention to this thread, strangely enough started by you......
http://forums.sv650.org/viewtopic.php?t=16566
Dan.
Old 12-05-05, 10:32 PM   #7
marshms
I know I did. I just wanted to get some other opinions. I'm still getting mixed answers. Some (like you) say it's normal. Others say it's not. How can I be sure? I don't want to blow the motor or something like that. I just got the fairing/cowls back from the painter and am in the process of installing them. Hopefully everything turns out fine. I'd hate for the $2k I've put into this bike to be for nothing.
Old 12-05-05, 10:41 PM   #8
fizzwheel
fizzwheel's Avatar
I never let my bike idle run on the choke that long, long enough to shut the garage door, put my gloves and lid on.. probably no more than 2 - 3 minutes.
How long are you letting it run at 3000rpm for before you notice the pipes glowing.
Old 12-05-05, 10:46 PM   #9
marshms
It runs at 3000 rpm's for less than 2 minutes before they start glowing orange/red. Choke is not a factor as it is shut off right after starting the engine. It has been garaged and that is where I noticed the glowing.
Old 12-05-05, 10:50 PM   #10
fizzwheel
fizzwheel's Avatar
Well all I can say is that mine doesnt do that.
K4 SV650S problem the_elements_600 SV Talk, Tuning & Tweaking 12 10-10-08 11:10 PM
2002 sv650s K&N problem erics02 SV Talk, Tuning & Tweaking 6 18-10-07 09:52 PM
problem wiv tyres on an old sv650s? weemanno1 Bikes - Talk & Issues 4 04-06-07 09:25 AM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
