Old 13-10-08, 02:14 PM   #1
remf179
Default Dead Curvy
Ok Ok so I sold the twin and have gone back to an in line 4 but I am after some help.
A mate asked me to check out his SV that wasnt running correctly (i was an auto electrician in a previous life). It seems that I may have dropped myself in at the deepend as he has heavily modified the bike and nothing seems standard!
Anyway, the main problem is that the bike fails to start 9 out of 10 times and when it does run, back fires badly with no revs or power .
The carbs have been checked and cleaned, all ignition circuits checked inc coils. I did find some "cut wires" where the owner said the ignition retarder was and that it had been disconnected.
The other issues that I discovered was that there is electrical current running through the frame of the bike. Looking for ashort circuit I discovered a very small amount of current going through the "meter" fuse with the bike switched off and key out of the ignition. Although a fault I fail to see if this could affect the running of the bike. I am inclined to think that the actual ignition switch is the main culprit but have yet to check it out.
Any other suggestions more than welcome!!
Remf
(PS I do miss my k7SV...sometimes)
Old 13-10-08, 06:30 PM   #2
BILLY
Default Re: Dead Curvy
Check the wiring loom on the rear subframe they have a tendancy to wear through there!
Old 15-10-08, 07:12 PM   #3
remf179
Thanks Billy, will have a look
Old 15-10-08, 07:19 PM   #4
The meter fuse runs the clocks to keep the trip meter memory so a small current (how small are we talking?) doesn't really suprise.
When it's running badly, just gob on the downpipes to check they're both running. Run it for a bit, then take a look at the plugs.
Old 16-10-08, 12:17 PM   #5
vardypeeps
Yeah check plugs. Is there any chance the HT leads are on the wrong way around?
Old 16-10-08, 12:21 PM   #6
No. Rear one won't reach the front plug.
Dead 02 SVS 2whelltraveler SV Talk, Tuning & Tweaking 4 12-05-09 01:25 AM
awake the dead curvy Nicky S SV Talk, Tuning & Tweaking 1 05-03-09 06:08 PM
Curvy dead :( Possible write off? Nicky S SV Talk, Tuning & Tweaking 31 31-10-08 12:39 AM
dead sv hlaf_lyfe Bikes - Talk & Issues 15 26-01-08 09:52 PM
HELP - Dead SV Roy650s SV Talk, Tuning & Tweaking 17 01-03-06 08:37 PM
