Old 26-10-08, 12:02 PM   #1
Peaceful
Default puttng motrax bar end mirrors on.
I recently bought motrax bar end mirrors for my sv, i thought to myself this should be easy to set up.. just use a phillips screwdriver to take off the bar ends and bish bash bosh your done!
But as i took my screwdirver to take off the barends i hit a problem either my bar ends dont come off or i am way too weak becuase those things just wont budge, i put WD40 on them and left it overnight and they still wont budge, anyone got any ideas? do i need to use a power drill or something like that?
btw my bike is a sv650 K3 Naked
Old 26-10-08, 12:06 PM   #2
Sean_C
Default Re: puttng motrax bar end mirrors on.
They can be stiff. HAve you got phillips bits you can use with a ratchet? Or an impact driver?
Old 26-10-08, 12:32 PM   #3
Peaceful
i may have one for rachet, dont even have a impact driver -_- i think i may just have summon godly stregnth and go at it again
Old 26-10-08, 12:37 PM   #4
dyzio
dyzio's Avatar
Impact driver, or some mole grips and try to unscrew the whole bar end
Old 26-10-08, 01:02 PM   #5
Peaceful
gonna try the mole grips to take the whole thing off.
Old 26-10-08, 09:08 PM   #6
Peaceful
Ah thanks i used the mole grips on the whole thing and it worked, thanks for the help.
Old 27-10-08, 01:06 PM   #7
vardypeeps
Yeah I'm having the same problem with mine and want to take them off to either paint or get new ones so will give the moley's a bash
Old 27-10-08, 01:18 PM   #8
Nicky S
Nicky S's Avatar
just go at it with everthing you got :P but if you have renthal bar ends then u can just put the mirro round it, that what i did
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 27-10-08, 02:52 PM   #9
Jase22
Shocking your screwdriver with a hammer can often work if you're not in posession of an impact driver. Also, Plus Gas is probably the best penetrative oil out there, and isn't that pricey. Plus you'll easily get your usage out of it.
I got a seized rear spindle out of r lass's 125 using Plus Gas, it's very good stuff.
Old 30-10-08, 03:20 PM   #10
Jase22
Did you get anywhere with your bar end then?
Remove Motrax DHM! veggiz SV Talk, Tuning & Tweaking 5 03-04-08 07:26 AM
Which stands to use? Motrax or?? 600+ Bikes - Talk & Issues 3 10-07-07 10:01 AM
Motrax DHM? Jase22 SV Talk, Tuning & Tweaking 24 14-11-05 07:00 PM
Motrax DHM mushrooms TC3 SV Talk, Tuning & Tweaking 6 08-06-05 05:07 PM
motrax l.e.d.s (again) stumpy1 SV Talk, Tuning & Tweaking 11 19-04-05 06:00 PM
