my netgear router slows down the longer its on? i keep having to switch it off for a few mins to reset? is this normal does anyone else have this problem?
The Sick Man
see if there is any newer firmware for it, ive seem this with a few routers that have limited memory and realy suffer with P2P and large ammounts of connections
In the world of dynamic IPs and P2P, even if you are not using P2P there are lots of people still trying to connect to your router (failing) but this still uses up the memory and cpu in the router. Ive had issues with a couple of routers, that would crash under high ammount of connections when using P2P
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Are you sure it's the router, and not your line slowing down. Remember that the router will talk to your computer faster than your computer can talk to the internet.
It could be a case of the IP profile on the line reducing until the modem re-sync's. An easy test would be next time it's slowing down, use the routers webpages to disconnect from the ADSL connection, then re-connect. That will re-sync without restarting the router. |
my dad has the same netgear router and sometimes his stops working compleatly and we have to turn the power off to reset that,
baph this happens on my lappy and my desk top which are both wireless. |
Ah - depends on the router some of the old netgear routers have a tendency to over heat. The two I had in work took them apart drilled holes in the case top and bottom (when circuit board is out). Then screwed a PC fan onto the top taking the power off the circuit board to the router - not a problem after that. The fan was one with golf ball dimples on the blades ultra quiet.
A little like this link http://www.flickr.com/photos/cbenard...7594171530437/ |
it isnt an old router but its weird that my dads does the same.
#8 | |
Captain Awesome
Official "Dumbass of the Year" 2011 (•_•) ( •_•)>⌐■-■ (⌐■_■) Deal with it... |
#9 | |
The Sick Man
Whats the model of the router
#10 |
The Sick Man
thats still 11Mbps, remember thoes are just ATM speeds, actual speeds are slower
Which wireless router? | StreetHawk | Idle Banter | 13 | 23-06-08 09:12 PM |
what router? | kwak zzr | Idle Banter | 39 | 14-11-07 05:21 PM |
Sky Router & VOIP | 600+ | Idle Banter | 8 | 01-05-07 06:32 PM |
Router and DSL Needed?? | Demonz | Idle Banter | 1 | 14-12-06 05:29 PM |
DSL router dead. | rictus01 | Idle Banter | 8 | 12-12-06 03:43 AM |
