Old 22-11-08, 09:23 AM   #1
hooters
Default Gear selection trouble.
hi all
i have a problem with my sv650 K5 it has only done 5000 miles and i keep on losing 1st, neutral and on the odd occation 2nd. the clutch is not slipping, it feels like when you try to put it into 1st or neutral it goes all spongy.
i really dont no what to do. ive checked the oil and clutch cable.
has any1 had this problem and how do you sort it.
thanks
Charli
Old 22-11-08, 10:39 AM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: problem with k5 sv650 PLEASE HELP
You could also check chain tension. I believe that would give some issues. Im sure YC will be along soon with his guru ways.
Old 22-11-08, 11:25 AM   #3
hooters
yer i have checked it and its fine
Old 22-11-08, 12:28 PM   #4
How long's oil been in there?
Old 22-11-08, 01:11 PM   #5
hooters
about 2-3 months
Old 22-11-08, 01:14 PM   #6
Miles?
When you say it feels like sponge? How you mean?
Old 22-11-08, 01:40 PM   #7
hooters
just under 5000 miles
when i try to grt into 1st or neutral it feels soft, spounge and squigy thats the only way to explain it.
it just wont go in
Old 22-11-08, 02:06 PM   #8
Well change oil then, that won't help.
Also check external shift mechanism is all nice and free moving (shifter and linkage), clean the crap off from round the shift rod.
Old 22-11-08, 02:28 PM   #9
hooters
i did one 2-3 months it does need 1.
ill give the shaft a clean. and see how i go
Old 23-11-08, 11:57 AM   #10
I'd put money on this being the problem. The selector can't reset and thus pressing the lever is only moving the return spring.
Gear selection problems Stingo SV Talk, Tuning & Tweaking 8 04-09-08 05:10 PM
Gear Selection Problems Iansv SV Talk, Tuning & Tweaking 14 12-01-06 03:14 PM
Gear Selection jpb SV Talk, Tuning & Tweaking 3 14-11-05 04:17 PM
Gear selection becoming difficult pridhac SV Talk, Tuning & Tweaking 8 16-02-05 09:04 PM
Gear Selection! PoRk ChOp SV Talk, Tuning & Tweaking 11 06-01-05 04:15 PM
