Old 18-12-08, 11:08 AM   #1
arcdef
Default replacing old R+G bung with new motosliders?
pretty much i need to take these old R+G bungs off........
http://s62.photobucket.com/albums/h1...8122008234.jpg
and put my new motorsliders on, however i understand how to fit the new ones but the top bolt where the bracket for the R+G bungs sits, will i need a standard bolt to go back on there or will that one still work???pretty sure its too long??
cheers
Old 18-12-08, 06:26 PM   #2
Dangerous Dave
Default Re: replacing old R+G bung with new motosliders????
Correct, you will need to replace both the left and right rear cylinder mounting bolts.
Part Numbers; 01550-10557 and 01550-10807.
You can order from Robinsons, they will take 2-3 days to arrive at your door.
Old 18-12-08, 06:45 PM   #3
arcdef
thats great, thanks for that, just means i will have to wait a little longer untill i can ride, out of interest why are they different part numbers and why is one more expensive??
cheers!
Old 18-12-08, 08:49 PM   #4
silent11
they are different sizes
Old 18-12-08, 08:51 PM   #5
Dangerous Dave
Yeap, that is why there are two part numbers above.
Old 23-12-08, 03:51 PM   #6
arcdef
which one goes which side ie is the longer one on the right or left!!!
cheers
Old 23-12-08, 05:09 PM   #7
arcdef
ok figured that out! what tension should i do these bolts up to though??
thanks
Old 24-12-08, 02:30 PM   #8
Dangerous Dave
Both rear cylinder mounting bolts need to be torqued to 55 Nm.
Motosliders simonthepost Bikes - Talk & Issues 64 24-01-10 09:27 PM
Motosliders svdemon For Sale - SV's and SV related items 2 09-10-08 12:09 PM
motosliders scottjames SV Talk, Tuning & Tweaking 5 08-10-08 06:46 AM
get your motosliders here dizzyblonde SV Talk, Tuning & Tweaking 9 06-03-08 01:37 PM
Bung installation query for dummies - Motosliders SV650S_DUB SV Talk, Tuning & Tweaking 8 15-02-06 08:53 AM
