Old 14-02-06, 10:04 AM   #1
SV650S_DUB
Default Bung installation query for dummies - Motosliders
Morning,
I've received a set of Motosliders crash bungs [complimets to them on swift delivery]. They've a long bar that runs the entire width of the engine. To insert said bar I need to remove a pair of bolts that run through the frame + engine. The bolts lie at the point where the upper and lower frame tubes are joined with an angled back tube, on curvy's at least. Can anyone tell me are these the main engine bolts and will I need to support the motor on a jack before I attempt to remove the bolts? Thanks for clearing up the doubts of a mechanical simpleton.
Old 14-02-06, 10:25 AM   #2
Cloggsy
No, the engine doesn't need supporting, its held in at several other points too
Make sure you torque the new bolt up properly though
Old 14-02-06, 11:57 AM   #3
jambo
jambo's Avatar
What that man said! Too loose or tight can lead to vibes, sheared bolts and even iffy handling
Old 14-02-06, 12:03 PM   #4
On a curvy you just remove one bolt for Nate's sliders- it's a very long stud with a nut on each end. And it'll be an absolute ****** to undo
Old 14-02-06, 08:28 PM   #5
seedy100
Mine were dead easy to fit (on a pointy)
Two sockets and ratchets helped though.
Torqued up and used thread lock (hope that was ok)
I got the bar end and swing arm sliders at the same time, they were a simple fit to.
Old 14-02-06, 08:29 PM   #6
seedy100
Two sockets and rachets helped though.
Old 14-02-06, 08:31 PM   #7
seedy100
Old 14-02-06, 08:38 PM   #8
seedy100
OOOOPPPS
Bit of finger trouble there.
SORRY!
Old 15-02-06, 08:53 AM   #9
Jase22
Make sure you follow the instructions and use loctite, my pops recently "tested" the bungs and one came loose when he dropped the bike.
We both though it wouldn't need the loctite as the bolt is a nylock one, but it does.
Racing for dummies captainsmelly Bikes - Talk & Issues 9 20-05-09 05:06 PM
replacing old R+G bung with new motosliders? arcdef SV Talk, Tuning & Tweaking 7 24-12-08 02:30 PM
iPod help for dummies (thats me)! please. SV-net Idle Banter 3 20-12-08 11:31 PM
winter storage for dummies drumroll SV Talk, Tuning & Tweaking 32 07-09-07 11:10 PM
