Old 09-02-09, 01:41 PM   #1
mackrilld
Default Fuel pump not coming on.
hello just when i throught everything was ok turn the ignition on and the fuel pump did not come on. On the dash the red light is on and says check,I HAVE CHECKED THE KILL SWITCH. Im gessing its because ive liffted the tank up to replace the spark plugs but have checked the electrical connectors around the tank area, so and help would be much apresiated thanks, Dom
Old 09-02-09, 04:37 PM   #2
thefallenangel
Default Re: Fuel pump not coming on.
there's a connector which stops it from priming on the right hand side as you sit on the bike, check it as it's what happened to my bike
Old 09-02-09, 04:51 PM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
not in gear with the sidestand down is it?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 09-02-09, 05:05 PM   #4
Dicky Ticker
Ever heard the expression "Disaster waiting for a place to happen" You most definitely don't have the best of luck.
Sorry just your posts are all problems so far and I have a warped sense of humour------------GOOD LUCK with your repairs
Old 09-02-09, 07:02 PM   #5
Baph
The "CHEC" warning only displays for a number of reasons (those that I can think of are as follows):
1. Kill switch (even though you've checked it, it could be faulty).
2. Side stand switch & gear sensor combination - ie. in gear with the side stand down. If you're definitely not in gear, bypass the switch to see if this is faulty.
3. Tip sensor (on the K6 this is located just next to the battery).
Old 05-11-10, 05:00 PM   #6
williums
I've a 2003 SV650 with a fuel pump problem. When you try to start it, the red FI comes on. There is no pump whine, but the bike cranks. I've checked the fuses, cleaned the kill-switch and all the connections I can find, including the sidestand, key barrel and TOS, but still nothing. It sounds like a bad fuel pump, but I tried dealer-mode, and got a C00 code.
I'm stumped - any suggestions?
Fuel pump problem, maybe. mudgutsdunn SV Talk, Tuning & Tweaking 5 11-03-10 11:54 PM
How do i remove the fuel pump on a K5 tonny006 SV Talk, Tuning & Tweaking 10 01-10-08 08:45 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
No dash + fuel pump ivantate SV Talk, Tuning & Tweaking 3 30-06-06 04:22 PM
