Old 12-02-09, 02:08 PM   #1
squariegoes
Default Leathers rubbing on tank?
My leather trouser are starting to cause rub marks on my tank. I've seen the sticky plastic sheets that can be cut to size and stuck to the tank. Are there any other solutions?
Old 12-02-09, 02:09 PM   #2
hovis
Default Re: Leathers rubbing on tank?
wear shorts*
* not in this weather though
Old 12-02-09, 02:11 PM   #3
Mr Speirs
Mr Speirs's Avatar
wear nothing
once again not in this weather
Old 12-02-09, 02:11 PM   #4
its the rubbish suzuki paint the black marks very easily, other than a good few coats of polish i dunno.
Old 12-02-09, 02:12 PM   #5
madness
Stompgrip
Old 12-02-09, 02:27 PM   #6
Rai86
Depends if you like the look but you could get a Bagster tank bag....that'l save the paintwork!
Old 12-02-09, 02:27 PM   #7
Viney
Originally Posted by madness View Post
Stompgrip
I would rather have rub marks on my tank. Got those things are ugly..and unessacary imho!.
Tank cover?
Old 12-02-09, 02:59 PM   #8
Bluepete
Bluepete's Avatar
I polished the marks out then put about five or six coats of good quality, hard wax on. So long as you remember to top it up now and again, it'll be reet!
Then again, YorkieChris would tell you to stop being ghey about it and slap some matt black stove enamel on!
Stomp-grip does look awfull mind you.
Old 12-02-09, 03:15 PM   #9
K
I used to have the 'titainium carbon fibre' on the BlueBlade, but needed to be replaced after a couple of years (just after this photo) as the top layer had started to peel slightly:
Though I'm fairly certain Motrax to do clear version that, when put on with care, is virtually unnoticable once on.
Old 12-02-09, 03:20 PM   #10
Davies
Tank cover?
I've found Stompgrips to be pretty useful, especially 2 up, but the side effect is that they rub your leathers away, which isn't too helpful.
Clearcoat rubbing off Maestro SV Talk, Tuning & Tweaking 7 20-04-07 08:40 PM
What is Rubbing Alcohol ? Richie Idle Banter 17 29-03-07 08:51 PM
Rubbing brakes HELP andy gooding SV Talk, Tuning & Tweaking 8 20-02-06 09:46 AM
Leathers rubbing on tank SPeeeeDY SV Talk, Tuning & Tweaking 14 11-07-05 11:10 PM
rubbing noise! caines SV Talk, Tuning & Tweaking 1 02-01-05 07:46 PM
