Hi all,
In the manual it describes the process of fitting new cylinder head cover gaskets. It mentions using 'Suzuki Bond' to seal the cam shaft end caps of this gasket. Whats the favourite replacement for Suzuki Bond that works well? Silicone seal? This looks like a good bet....http://www.halfords.com/webapp/wcs/s...9738&langId=-1 Last edited by flymo; 15-02-09 at 09:24 AM. |
Hylomar Blue or any non permanent gasket sealer. If the seal is in good nick it's overkill anyway.
I have a rocker cover gasket part no. 11173-19FO1 if you want it on the cheap give me a shout.
#4 | |
Damn, just ordered two new ones. How many do you have, just the one? |
Yeah just one mate
I've never bothered, my covers have been on and off a few times and work perfectly with no sealant.
#8 | |
A few other SV's the same.
#9 |
old thread bump,
do i need new cylinder head gaskets when removing the head cover to get to the cams? at £20 each they are a bit costly to replace if they dont really need doing and do i just seal it(old gasket) with this when im done ? LINK Last edited by barwel1992; 04-10-10 at 11:30 PM. |
#10 |
No.
The cam cover[1] gasket is rubber so unless you damage it you shouldn't need to replace it. Some people advocate using a smear of RTV or similar (like that locktite) when refitting to ensure oil tightness. Druid [1] And you only need to take the cam cover off to swap cams, not the head.
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F Last edited by fastdruid; 04-10-10 at 11:33 PM. |
Cometic head gaskets | LEXINGTONONE | Stuff Wanted | 1 | 27-04-09 08:22 PM |
Cometic Head Gaskets | LEXINGTONONE | SV Talk, Tuning & Tweaking | 0 | 21-04-09 03:59 PM |
Leaking rocker cover gaskets | flymo | SV Talk, Tuning & Tweaking | 5 | 18-03-09 11:38 AM |
How to Identify K3 Cylinder Head | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 2 | 03-05-07 12:24 AM |
Fitting exhaust gaskets | andyaikido | SV Talk, Tuning & Tweaking | 4 | 19-02-06 05:29 PM |
