2001 curvey.
can you buy new seals and valves for the fuel pump or are they not replaceable. ? one of the valves on mine has fallen part through the hole and has creased. it keeps doing it now and i need to eliminate this so i can carry on finding my starting problem. many thanks scott |
Suzuki don't supply internal parts for the fuel pump. IIRC a new pump cost about £50, there is a low degree of certainty about that though - it was some time ago.
Failures are rare - I'm sure you'll be OK with a S/H one.
As above.
Sorry to teach grandma to suck eggs... but you are on about the fuel pump and not the vacuum tap right? The fuel pump is on the RHS of the frame, the tap is on the bottom of the tank.
defo the fuel pump. but thanks any way chris. always good to double check.
still not sure whatscauseing my starting problem. |
Fuel pump problem, maybe. | mudgutsdunn | SV Talk, Tuning & Tweaking | 5 | 11-03-10 11:54 PM |
Fuel pump | cornishrider | SV Talk, Tuning & Tweaking | 6 | 02-03-08 07:25 PM |
Cables and valves (and seals and sealers) | ejohnh | SV Talk, Tuning & Tweaking | 3 | 13-02-08 07:59 PM |
K5> fuel pump | phil24_7 | Stuff Wanted | 11 | 29-10-07 05:18 AM |
No dash + fuel pump | ivantate | SV Talk, Tuning & Tweaking | 3 | 30-06-06 04:22 PM |
