Old 10-04-09, 09:25 AM   #1
TheShadow
Default Looking for some help with a shock
I recently won a 2008 ZX10R shock on ebay http://forums.sv650.org/showthread.php?t=129384 I did not appreciate that these shock are significantly different to the <2008 shocks when i bought it.
Looking at pictures of the shock I may have to move the battery box etc before having the shock fitted.
Would anyone like to volunteer a hand for the battery box alterations and maybe the shock install.
I am live in the renfrewshire area
Cheers.
Old 10-04-09, 09:29 AM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
But seriously...
Get a dremel and work out what needs cutting, just make sure you can get away with just cutting the battery box and not the stuff inside it
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 10-04-09, 09:44 AM   #3
dyzio
dyzio's Avatar
Default Re: Looking for some help with a shock
Hello,
I did the zx636 c1h on my curvy, the battery box needed cutting as well as the tank hinge.
Only saw 1 zx10 fitted (didn't need the hinge cut) but that was an earlier model.
Get a sharp stanley knife, cut what needs cutting, the battery still goes it the same place (I THINK this will be the same with the 2k8 shock), It will sit on the shock reservoir, so put some padding there (mine was ok after 8 months and 5k miles) you'll have to bin the top battery tray and relocate the fuse box. you also might have to cut the tank hinge, I used a junior hack saw.
Useful tool: rubber mallet.
Unfortunately I live on the other end of Scotland :/
Useful thread:
http://forums.sv650.org/showthread.p...ighlight=shock
HTH
Old 10-04-09, 09:52 AM   #4
husky03
i'll check with the mrs and see what she's got planned with midwife etc-if i'm free you can come over and we'll get it done-when you looking to do it
Old 10-04-09, 10:23 AM   #5
TheShadow
Husky,
Shock has not arrived yet and i am still trying to find somewear to buy the correct Kwak bolt from.
I am in no rush to get it done, if a weekday suits you better give me a shout and ill try and book a days holiday.
Cheers!
Old 10-04-09, 10:31 AM   #6
dyzio
dyzio's Avatar
Originally Posted by dyziowg View Post
Glad to be of service
Imagine, I did find a dealer Email these guys http://cradleykawasaki.co.uk/ and tell them you're looking for a 10x55 bolt and nut to fit a zx shock to an sv
L6,80 posted, they take paypal.
Originally Posted by erik View Post
The Kawasaki part number for the M10 62mm bolt for the 03-04 zx6r is: 92151-1601
the nut is: 92210-1139
The 05-06 zx6r seems to have a shorter 55mm bolt (but uses the same nut): 92153-0663
I got the above Kawasaki part numbers from the online microfiches at http://www.ronayers.com/ it's a really useful site for looking up part numbers! It also has a reverse lookup thing that lets you see what other bikes share the same part, quite cool I reckon!
http://www.bikebandit.com/ also has online microfiches, but it doesn't list the manufacturer's part numbers.
Hopefully I'll be getting an '05 zx6r shock on sunday for my sv.
This should be it
Old 10-04-09, 03:50 PM   #7
TheShadow
This should be it
Thanks for that lot.
I reverse looked up the 2 bolts below and neither of them share the zx10 platform. So still pretty stuck.
I can find the parts diagram of the zx10r on that site but it doesnt give you a part number next to the item.
Old 10-04-09, 04:08 PM   #8
dyzio
dyzio's Avatar
Give them a call or send them an email and ask about a bolt for the "fork" end for your shock. They will be able to help you.
Old 11-04-09, 11:17 AM   #9
TheShadow
Superb managed to order the bolt and nut for a 2008 ZX10R. Thanks for the help, the "fork" end description helped.
I just have to wait on both the shock and the bolt/nut being delivered and then hope that the damn thing fits.
I am sure with Husky's help it will "fit".
Old 15-04-09, 04:25 PM   #10
TheShadow
Shock arrived. Do you lot still think it will fit?
SV650 K6 shock & GSXR1000 K4 Shock weecorey For Sale - SV's and SV related items 0 03-05-09 08:02 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
