Old 24-04-09, 08:12 AM   #1
Mr_Chin
Mr_Chin's Avatar
Default Revs dropping in Mid range
Hi Mighty Orgers
I need a bit of advice from you knowlegeble lot regarding the above on my K3 pointy.
I have recently noticed that the idle needle drops in revs within the mid range around 4-4.5k down to about 3.5k. I haven't noticed it before, and have had a stubby on the bike for about 4 months now.
Could the likely cause be that I need the throttles balanced or the TPS adjusted?
or is this what I have to put up with due to stubbying my exhaust?
If the latter, I'll definately put up with it, but like I say, I've only recently noticed it happening.
BTW, bike has circa 16k on the clock if that makes a difference.
Any helpful advice welcome.
Thanks.
Chin
- SK4.SV650.2004.YC2
- D3N15
Mr_Chin is offline   Reply With Quote
Old 24-04-09, 09:19 AM   #2
chompy
Default Re: Revs dropping in Mid range
you could try adjusting the TPS but i dont know if it would make a difference there is a thread on here with pictures that tels you how to do it, looks pretty straight forward although i dont need to do it because i have a curvy
Dropping helmets sauluk Bikes - Talk & Issues 30 28-10-08 01:19 AM
Fuel - Wow... its still dropping Grinch Bikes - Talk & Issues 34 15-08-08 09:20 AM
why does my wireless keep dropping on and off blueto Idle Banter 11 27-06-08 03:27 PM
Dropping the yokes down the forks? Berlin SV Talk, Tuning & Tweaking 4 20-09-07 10:55 AM
Dropping the forks through the yoke Jase22 SV Talk, Tuning & Tweaking 25 29-05-06 03:15 PM
