Old 05-05-09, 09:26 AM   #1
BoltonSte
Default 20K Service
Before I look into this too much, is the 20K one of the big ones (valves etc) or one of the smaller services? What's the next one like?
Mines due, but due to previous services over running ever so slightly, it's actually up to 22K (first service since I've owned the bike)
So I'm thinking, if this isn't a major one then do it myself (I'm happy enough to work on the bike, just finding the time) to get my teeth in. It'll save me money and I can get the servicing back on track with the next one.
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 05-05-09, 09:32 AM   #2
Dave20046
Dave20046's Avatar
Default Re: 20K Service
Not sure but you could start by doing the oil, oil filter, air filter and sparkplugs yourself then lube everything check the brakes/rubber/chain etc. then if there's anything additional due try that or take it to the garage if it's a bit out of your comfort zone.
Someone helpful will be along soon anyway with the service guide
Old 05-05-09, 10:08 AM   #3
pencil shavings
15k is the major one on the pointy. So if that the same for a curvy I would say it is the first minor service after the major service. HTH
Old 05-05-09, 10:08 AM   #4
Dave20046
Dave20046's Avatar
Yeah the 15k is the major one on the curvy too (valve clearances etc)
Old 05-05-09, 11:21 AM   #5
BoltonSte
Cheers, there's little I won't try. It was mainly around timing for me to do it vs. a pro or if there was going to be anything that needed a judgement call, which their experience would be better than mine.
I'll have at it then.
What's the best source for a list of what needs to be done at each service?
Ste
Had an SV or three.
Old 05-05-09, 11:27 AM   #6
Dave20046
Dave20046's Avatar
There's possibly links on www.sv650.org/faq if not someone will point you in the right direction.
Old 05-05-09, 12:15 PM   #7
pencil shavings
Ste
get a hynes manual. tells you everything that needs to be done and how to do it. you will need it if you are doing your own servicing.
Old 05-05-09, 04:49 PM   #8
breakz187
Do they usually need adjusting at this interval? Do you usually find they actually need adjusting? Think mine will need to be done soon.
Old 05-05-09, 05:00 PM   #9
or a Clymer, I find it has better pics and at times a bit more in depth than a Haynes, I have both to cross reference.
They don't always need adjusting, but you don't know until you've looked, but I wouldn't leave it too long after 15k, 30k etc
Old 06-05-09, 12:17 PM   #10
Alpinestarhero
When my clearences were checked at 30k, my dad noticed the hard casing material had worn off two of the cam-followers (cup-type things). He managed to replace the worst one, but the other one will need doing next time. Apparently, this was a problem with the 1999 SV's and also the TL1000's as suzuki had made a manufactuing error, leaving the hard-coating too thin and easily worn away (a part of me is concerned about lubrication aswell, and the histroy of my bike...)
Just have a good check. New ones are around £50 each.
i think my wallet just fainted at being reminded that
what do i need for a DIY service? chompy SV Talk, Tuning & Tweaking 20 04-03-09 11:18 PM
Service my SV ukrobuk Bikes - Talk & Issues 1 19-02-08 08:59 PM
Citizens Service - the new National Service. grh1904 Idle Banter 11 06-09-07 11:44 AM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
first service macdo Pennine Massive 5 09-09-05 06:45 AM
