Old 02-06-09, 12:41 PM   #1
Swin
Swin's Avatar
Default Fuel under a K9 - overfull?
Mate's just phoned me up, he's got a brand new 09 SV Sport.
Tells me that there's petrol puddling under his bike if he leaves it anywhere, only a small amount and he thinks it's exiting from the breather tubes behind the rear brake pedal.
I'm wondering if it's simply overfilled, as I say he's new to the SV and may have put a bit too much fuel in - any other ideas for this?
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 02-06-09, 12:43 PM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: Breather tubes
Overfilled is most probable.
Old 02-06-09, 02:19 PM   #3
suzsv650
Brimmed then left in the sunn probably
the heat from the sun will make the petrol expand that much to come out of the pipes
Old 02-06-09, 03:41 PM   #4
Kuze
+1 to post above i was forever doing this on my new bike at the time er6f, so its not likely its rolled out the garage defective.
Old 02-06-09, 04:08 PM   #5
Swin
Swin's Avatar
Thanks guys, I'll give him a bell and set his mind at rest
I'd hazarded a guess at the same, but only having had an SV for 3 months I'm not fully up to speed on it little quirks myself yet!
Old 02-06-09, 04:11 PM   #6
SoulKiss
SoulKiss's Avatar
My tank is almost empty at the moment - but look for my thread this morning about my bike whistling.
I would bet that had I more fuel in it then I too would have a puddle.
Old 02-06-09, 04:16 PM   #7
Swin
Swin's Avatar
Yes, I read your thread about a pressurised tank - when I was scouting around for any other explanations. Have you found the blockage yet? if not, good luck
Old 02-06-09, 04:23 PM   #8
SoulKiss
SoulKiss's Avatar
Seems to be common on Kwaks and may not be due to a blockage.....
Old 02-06-09, 04:41 PM   #9
Kuze
If it helps my er6 whistled all the time and occasionally opened with a pop as the pressure equalized.
Dealers never thought anything of it!
Which uses less fuel? jimmy__riddle Idle Banter 26 17-11-08 11:00 PM
Fuel rs_tubby SV Talk, Tuning & Tweaking 6 27-05-07 01:44 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
The most fuel you've put into your SV. neilhatch Bikes - Talk & Issues 34 12-12-06 01:32 PM
Dry fuel BURNER SV Talk, Tuning & Tweaking 8 18-11-05 05:09 PM
