Old 06-06-09, 10:40 AM   #1
svdemon
Default MOT failed "loose swing arm"!
Just got the call form my MOT place to say my bike has failed because the swing arm is loose !!!!!!
Going down to get it just now, i take it i'll be mostly replacing all the bearings in the swing arm and suspension linkage this weekend then?
Any tips would be appreciated as i've never done this before although i have changed the shock.
Old 06-06-09, 10:44 AM   #2
Default Re: MOT failed "loose swing arm"!!!
special tool, axil stands, grease, bearings.
Old 06-06-09, 10:50 AM   #3
svdemon
Whats the special tool, i'm gonna order bearings when i'm at the garage as i can't find some of them on simply bearings.
Whats a good grease?
Old 06-06-09, 10:52 AM   #4
svdemon
Bibio would i get away with using a 25x32x35 bearing instead of the 25x33x35 suzuki use?
Old 06-06-09, 10:54 AM   #5
http://cgi.ebay.co.uk/NEW-SUZUKI-SV6...A1%7C294%3A200
bearing grease, i'll check simply bearings... gives a few moments...
Old 06-06-09, 10:59 AM   #6
svdemon
Anyone got one of these i could borrow for a day? The guy wants £25 for them!!!
Old 06-06-09, 11:16 AM   #7
flymo
flymo's Avatar
You already own the bit on the right, its £20 just for the left one
Old 06-06-09, 11:16 AM   #8
yup... simply dont list them.. could always give them a phone... they are a weird size..
another thing you could try is just packing them with grease... how many miles has the bike done?
Old 06-06-09, 11:42 AM   #9
Don't use the smaller bearing it needs to be right size. For castellated nut just take a grinder/dremel to a normal socket.
Old 06-06-09, 11:47 AM   #10
svdemon
Got the fail sheet and its no where near as bad as the lady on the phone made out!!! The "rear suspension bearing has slight free play" !!
So i cann worry about that after its MOT'd.
The fails were - "nearside headlamp aim too high" easy peasy
and "exhaust noise is clearly in excess of that emitted by a similar motor bicycle fitted with a standard silencer in average condition" steel wool anyone?
So thats a relief but i'll do the swingarm & suspension bearings anyway once i can source bearings.
Failed my theory Magnum Idle Banter 28 17-02-09 12:40 PM
Clocks Failed -then OK again Duke SV Talk, Tuning & Tweaking 4 25-01-09 05:16 PM
failed again shiver85 Bikes - Talk & Issues 5 17-05-08 12:04 PM
TRE mod failed on 07 vegacr250 SV Talk, Tuning & Tweaking 21 09-07-07 10:28 PM
MOT failed Grinch SV Talk, Tuning & Tweaking 8 26-06-06 06:32 PM
