Old 08-06-09, 08:40 AM   #1
mrhighlyrated
Default Engine rattle
Hi guys, a couple of weeks ago and friend and I fitted a new rectifier and battery to my 99 curvey SV650. The day after I was plodding along to work when i started to hear a rattle from the bike, at first i put it down it being a screw we hadnt tightened on the tail fairing. As you can imagine we found out it wasnt this. It came to light that the rattle was coming from the front left of the engine which would suggest it was the cam chain tensioner being loose. So my friend and I tightened the cam chain ten, with no affect. I was pretty low on oil at this point which we re-filled with about a litre and a bit. So yesterday we took the front cover off the engine off to check the cam chains and to ensure the shims were all ok etc. They were all fine tight and in accordance with the Haynes manuel.
The rattle only appears when i accellerate and will disappear if i plod along at a steady speed. as soon as you give it any throttle it comes back. If you pull the clutch in it also disappears! over the last day or 2 it has also stated to sound like there are 2 rattles! 1 when you accellerate sounds like a vibrating rattle and now the 2nd noise is like a push bike noise when your not peddling. Can anyone shed some light??? or have any ideas??
Thanks
Old 08-06-09, 08:44 AM   #2
skidmarx
Default Re: Engine rattle
Not the chain is it? It's have to be pretty fubared to do this tho.....sure you've checked it just thought I'd start with the simple stuff first!
Old 08-06-09, 08:47 AM   #3
Alpinestarhero
At what level is the engine oil at now (just so we're all clear, oil is measured with the bike upright and not on the stand. Might seem a trivial point, but some people have reportedly topped up oil with the bike on the sidestand. D'oh!)? My SV makes rattles and all sorts when the oil is about midway or below, it prefers to have oil in the top 3rd of the window.
As skidmarx has said, check your final drive chain too. Dry, old, flappy chains will make alot of noise.
Old 08-06-09, 08:49 AM   #4
mrhighlyrated
Defo not the can chain we ran it around by hand when we had it open and no damage or probs.
Old 08-06-09, 08:50 AM   #5
mrhighlyrated
Oil is all level with bike up-right
Old 08-06-09, 08:51 AM   #6
skidmarx
Sorry I meant the final drive chain to the back wheel! Sure your cam chain would be fine unless you've done some serious mileage.
Old 08-06-09, 08:53 AM   #7
Alpinestarhero
inspecting a cam chain while turning the engine over a 10 revolutions per minute is going to give differing results to what a cam chain is really doing with the engine at 5000 revolutions per minute
when was the last oil-change?
Old 08-06-09, 08:55 AM   #8
Swin
Swin's Avatar
Different bike I know, but my old Bandit had a similar rattle which turned out to be the clutch basket
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 08-06-09, 09:11 AM   #9
mrhighlyrated
Last oil change was about a year ago
Old 08-06-09, 09:12 AM   #10
mrhighlyrated
The noise is defo coming from the front end
New K8 rattle mustnt grumble SV Talk, Tuning & Tweaking 15 13-04-09 09:55 AM
What's this rattle northwind SV Talk, Tuning & Tweaking 10 07-05-08 06:42 PM
Rattle? barmy.biker SV Talk, Tuning & Tweaking 8 30-11-07 07:49 AM
Engine Rattle svk2 Bikes - Talk & Issues 2 10-05-07 03:25 PM
Engine Rattle lukemillar SV Talk, Tuning & Tweaking 0 06-09-06 07:25 PM
