Old 10-06-09, 01:12 PM   #1
RatchetJob
Default Info: Dimensions of Curvy Restriction Washers
If you are trying to source 33BHP (25KW) restriction washers or make them yourself here is the relevant information you will need.
These measurements apply only to the washers for the curvy SV650, they are designed to work with carbs NOT fuel injection.
External Dimensions:
  • 1mm thick
  • 44 mm in diameter (44.23mm)
The aperture is:
  • 18mm (18.41mm)
  • Circular
  • Exactly in the middle
Fitting guidance
The washers fit under the carbs, i.e. between the bottom of the carbs and the engine.
You will need two, one for each carb.
Proof of Restriction
If your insurance company requires you to provide proof that your bike is restricted most will accept a Dyno printout showing the following details:
  • Date
  • Bike VIN/Reg
  • A maximum power output of less than 33BHP (25KW)
However, it is your responsibility to check with your insurance provider what proof is acceptable to them prior to restricting your engine and arranging insurance.
What they look like
Old 10-06-09, 02:58 PM   #2
Default Re: Info: Dimensions of Curvy Restriction Washers
I reckon this should be sticky. On my bookmarks anyway.
Old 10-06-09, 03:11 PM   #3
davepreston
defo a sticky i shall be annoying my work for some of these
Old 10-06-09, 08:35 PM   #4
Nicky S
Nicky S's Avatar
best info i have seen in a while
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 08-11-09, 03:00 AM   #5
pce13
Thank you for this info as i couldn't find it any where else...
Old 08-11-09, 10:47 AM   #6
Alpinestarhero
+1 for sticky.
if people can make the restrictors themselves, they stand to save a whole heap of dosh!
Old 14-12-09, 08:33 PM   #7
tobie14
will these washers work on a 2000 sv650s?
Old 14-12-09, 10:57 PM   #8
Yes any 99-02 model. If it has carbs it will work.
EFI model won't be much different but a throttle stop is needed too.
You could just fit them straight in of course, but it would run like an absolute dog as it would be monster rich.
Old 12-04-10, 08:59 PM   #9
rob_rossi_46
does anyone have any of these for sale? i really need them asap and dont have the time to make!! i have an sv650 SK2 2003. i need these two washers please!
Old 25-07-12, 08:29 AM   #10
alcanning
Smile Re: Info: Dimensions of Curvy Restriction Washers
Hi everyone i have come across a site which laser cuts Washers for the curvy sv650.
Here is a link to the site.
http://lasermaster.co.uk/metalshop/i...oducts_id=1732
ordered mine using dimensions and perfect all for cost of £5.50 delivered.
Thanks to lasermaster.co.uk.
standard curvy naked bar dimensions noob-saibot SV Talk, Tuning & Tweaking 0 23-02-09 06:02 PM
curvy restrictor washers adam_castell SV Talk, Tuning & Tweaking 3 16-01-09 01:19 PM
Curvy restrictor washers SDMF For Sale - SV's and SV related items 28 02-11-07 04:16 PM
restriction washers stooster SV Talk, Tuning & Tweaking 4 26-02-07 03:15 PM
Restrictor washers for Curvy turlock Stuff Wanted 1 16-10-06 07:39 PM
