Hi,
I have a prob with my bike. I'm sure it's a schoolboy error, but I think i've checked the normal stuff and am now struggling as to what to try next. The engine starts but then it goes straight up to 6.5k rpm then stays there, it will rev ok from there. I've adjusted the cables and the adjusters on the throttle bodies right down for max slack, as well as the idle adjustment, but it's made no difference. The cables have plenty of play, aren't tight, and look almost unused, as do the throttle bodies. Should i take the throttle cables off and see what happens perhaps? Can anyone help?? thanks!! ![]() |
Take them off, try it then..put them back on.
![]() Won't do any harm, surely? |
The bike is going into fast Idle but at this time of the year it should back off after a very short time due to the fast Idle being temperature sensitive . I would not take the throttle bodies apart as the manual states that you need to keep the link plates together .... if you do remove them then take them off the bike as a matched pair . Have you tried touching the bodies with a screwdriver whilst running and see if they "Click" back into place , mine used to stick a little bit `til I lubed the pivots on them but this was nearer the point where they were almost home .
i've since realised i forgot to connect the pipe that goes from the throttle bodies to the air temp sensor
That has got to be the prime culprit , I started my bike up this morning and straight away it went to 1.5k Idle as it isn`t cold enough to go to fast Idle , if you are not sending the Temperature signal to the ECU then it will probably sit there at fast Idle until told otherwise .
For anyone interested, this is now sorted, though only a change of throttle bodies sorted it (had an old grubby set knocking about). Disconnecting the throttle cables done nothing, as did connecting the pipe to the air sensor or swapping the ecu, same issue each time. Something on the throttle body unit wasn't happy, throttle position sensor perhaps or something?? though the factory markings hadn't been moved (by the look of it). It likes it old grubby one's anyway so it's all good!! cheers!!
![]() Last edited by MG#43; 13-06-09 at 07:00 PM. |
6500 rpm is not a fast idle - 2500 rpm is a fast idle. 6500 rpm is Destructive Idle!
Glad you got it sorted, but it could have been expensive...how much are new throttle bodies? |
#9 |
new doesn't even bare thinking about!!! used ebay jobs £35>, tho the one's i got were lemon or there's poss a difference in settings between k3-k4 v k5... (older one's worked ok but all look the same to me)..?
Curvy starting and Idling Problems | gavinsky23 | SV Talk, Tuning & Tweaking | 13 | 12-10-08 08:55 PM |
Idling High (4000rpm) once warm | SV_Ridin_Newb | SV Talk, Tuning & Tweaking | 3 | 16-08-07 05:16 PM |
Engine idling fast - what's up? | huge | SV Talk, Tuning & Tweaking | 5 | 21-02-06 11:52 AM |
Strange Idling Problem | fizzwheel | SV Talk, Tuning & Tweaking | 5 | 30-01-06 09:41 PM |
SV is idling at 500/600 rpm | Noufy | SV Talk, Tuning & Tweaking | 7 | 26-01-06 01:40 PM |
