Old 13-06-09, 12:21 AM   #1
breakz187
Default suspension going off?
How do you know when your suspension is going off and wearing out? Mine seems to be getting too stiff. When i corner at low speeds over bumps, the bike gets unsettled alot more than it used to. Its as if my suspension is hardening up. I think its the front end.
Is there a mileage at which your meant to replace fluids in the shocks?
Think its getting close to front end swap time...either that or new bike, but im almost sure i want to stick with the SV instead of changing to a ninja or vfr.
Old 13-06-09, 12:38 AM   #2
Jamiebridges123
Default Re: suspension going off?
Shocks do deteriorate, I don't think shock on the SV isn't rebuildable.
Maybe get some progressive springs and a GSXR shock or something.
But if it's the shock, I thought it lost it's dampening and got all wallowey.. have you checked fork seals and the like? Tyre pressures etc all make a difference..
Old 13-06-09, 08:20 AM   #3
As they wear they tend to become softer. Then again yours could be so soft it's landing on the bump stops too easily and thus feeling too hard.
Fork oil and springs isn't a hard job, but it's also possible rear linkage has seized. Does the rear bounce about freely?
Old 13-06-09, 09:52 AM   #4
Dan
I think you're wrong, IIRC, it isn't rebuildable.
Old 13-06-09, 02:37 PM   #5
It's not, and why would you bother anyway, they don't work properly when new.
Old 13-06-09, 02:39 PM   #6
bounces like a bloody bouncy castle, and your eyeballs jump up and down. HTH
Old 13-06-09, 03:54 PM   #7
tonksy154
Pump your tyres up, cheaper and an instant fix!
Old 13-06-09, 04:44 PM   #8
breakz187
IU think its the front forks though. Does it die in the same way?
Old 13-06-09, 05:08 PM   #9
Yes, the oil loses its viscosity with use and you lose damping force.
Old 13-06-09, 05:28 PM   #10
Alpinestarhero
Depending on use, it helps to change the fork oil every few years. The rear shock goes off, i didnt realise how bad mine was until I rode a 6000 mile bandit. I'll be sourcing a new one (GSXR one probably to save dosh), and as others have said the damping unit in the SV shock is not re-buildable (although the spring can be replaced).
How many miles on the bike?
suspension help Lucas66 Bikes - Talk & Issues 17 12-04-09 11:49 AM
Suspension - again - sorry!! pencil shavings SV Talk, Tuning & Tweaking 11 25-05-08 11:26 AM
Suspension (again, I know, sorry!!) JamesMio SV Talk, Tuning & Tweaking 9 13-03-08 06:22 PM
Suspension Cos SV Talk, Tuning & Tweaking 4 17-05-05 12:26 PM
suspension set-ups . . where ? Warren SV Talk, Tuning & Tweaking 9 06-05-05 06:11 PM
