Old 16-06-09, 11:54 AM   #1
CheGuevara
Default Hel Brake lines -custom
I ordered these for my GSXR front end conversion with risers/fat-bars. I guessed that SV-N length, with GSXR (K6/7 600/750) fittings would be about right, but they're a little on the snug side.
These are brand new and have never been filled with fluid (although there may be some that's dribbled out of my "empty" M/C into the line). I have mounted them to the bike (just more than finger tight, so the crush washers are still good), and while the fit is probably OK, if I can sell these quickly I'll order a new set an inch or so longer.
I suspect the length difference might be in the banjo-fitting position on the caliper end, or the bars I'm using. I can measure these ones, but length s/b whatever Hel specs for an N.
Probably suitable for a conversion using non-radial brakes. Might work with a stock N, or even an S if you don't mind them a little on the long side.
Black end fittings with carbon cover (that's smoke really, not a fake carbon-weave look). £40
CheGuevara is offline   Reply With Quote
Old 16-06-09, 04:45 PM   #2
stevo_sv
Default Re: Hel Brake lines -custom
If its not too much trouble could you measure them please?
I'm in need off some for my gsxr caliper's.
Old 16-06-09, 05:22 PM   #3
CheGuevara
Will do - I have to spend some quality time with the wife this eve, but will head out to the garage in the AM before work (unless I can find the measurements I took previously before then)
Old 16-06-09, 06:57 PM   #4
CheGuevara
Managed to steal a few precious garage moments. Results (both centre-of-banjo to centre-of-banjo, give or take a few mm as best I can hold the line and a tape measure straight):
RHS = 760mm
LHS = 735mm
Old 19-06-09, 04:41 PM   #5
stevo_sv
i managed to mock up the length i'd need earlier and yours are about 3-4cm too short
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
brake lines. x Silver x SV Talk, Tuning & Tweaking 10 03-01-09 09:11 PM
Custom length brake hoses DarrenSV650S Bikes - Talk & Issues 18 30-11-08 01:18 PM
Brake LInes vardypeeps SV Talk, Tuning & Tweaking 6 02-10-08 04:38 PM
Brake lines Barty_b0y SV Talk, Tuning & Tweaking 4 24-02-05 05:32 PM
