Old 25-06-09, 08:17 AM   #1
Lucas
Question My SV not starting
got on bike, turn key to 'on' position, lights comes on ok, normal etc. clutch in and press the starter button, motor turns over, a few seconds later cuts off
lights on the panel is still on, so clutch in and start again, motor makes a little turn then everything cuts out!
key is still in 'on' position, but lights on panel are now gone, turned the key a few times still nothing, not a light, noise... i have no idea
i've checked the killswitch, sidestand position. all the fuss in the main fuss box are fine.
I'm now charging the battery, but I dont think its the problem.
Could it be the starter relay?
Edit: my bike was in a Arson Arrack last week, could this be the cause? there are no surface damage to the bike, but could the heat cause some sort of interenal damage? but then again the bike get hot running normally anyway so I can't see it being the cuase.
cheers guys
Old 25-06-09, 08:27 AM   #2
Holdup
Default Re: My SV not starting
I wouldnt of thought so if its cutting every thing out, maybe just flat it happened to me once or could be some thing more serious, maybe the battery couldnt handle the heat from the fire?
Old 25-06-09, 08:37 AM   #3
Lucas
yeah, you could be right about the fire, it is on my mind. the heat did melt the cover but the body work seems ok, maybe the heat managed to somehow get pass and weaken some wires or even the battery, cuasing internal damages
Old 25-06-09, 09:22 AM   #4
Bubbidge
Regulator rectifier maybe? Had to change mine recently....
Old 25-06-09, 09:44 AM   #5
Alpinestarhero
The batery might have got hot and sort of discharged itself...batteries dont like high temp or low temp.....but then it gets arm around the battery when your riding anyway
Let us know what goes on
Old 25-06-09, 09:47 AM   #6
Chewie
Sounds like a cooked batterie!
Old 25-06-09, 10:14 PM   #7
Lucas
charged the battery all day, put it in, still nothing key to on, nothing, no light, noise nothing.
any ideas?
Old 25-06-09, 10:32 PM   #8
Bubbidge
telling you mate, regulator rectifier! worth checking it out
hope you get it sorted soon
Old 25-06-09, 10:52 PM   #9
Why this?
Lucas, PM me your phone number we'll talk and I'll offer some sensible suggestions.
Old 25-06-09, 11:05 PM   #10
Bubbidge
Why this?
Cheers for that. just trying to help - wont happen again.
Not starting Ben Flanagan SV Talk, Tuning & Tweaking 4 27-08-08 07:57 AM
not starting frankie77 Bikes - Talk & Issues 0 15-08-08 05:51 PM
Wow - Just starting out Grinch Idle Banter 38 29-11-07 06:05 PM
Help starting up Spewy SV Talk, Tuning & Tweaking 8 03-04-06 12:07 PM
Starting to look better !! Supervox Photos 9 03-09-05 02:41 PM
