Old 09-07-09, 01:18 PM   #1
SUPERSTARDJ01
Default New exhaust re-jetting?
Hi,
I've got a new ART exhaust slip on but it also has the back pipe for the exhaust will this need re-jetting and if so what is re-jetting??
Old 09-07-09, 01:51 PM   #2
suzsv650
Default Re: New exhaust re-jetting???
Dont worry you dont need to re-jet it for a end can
Old 09-07-09, 02:21 PM   #3
Kuku
If i can use the thread.....
For new custom made full exhaust (almost without end can - reeeeealy smal one, only for good looking) of pointy with K&N air-filter do i must change something to injection system?
It works perfect and sound amasing, but i'm not shure that it's allright for the bike?!
Old 09-07-09, 02:40 PM   #4
suzsv650
Prolly running a bit lean with the filter too, might be worth getting a re-map to get the power gains (if any). It'l prob be alright tho
Old 09-07-09, 02:47 PM   #5
SUPERSTARDJ01
How would I re-map?
Old 09-07-09, 03:14 PM   #6
suzsv650
Originally Posted by SUPERSTARDJ01 View Post
How would I re-map?
You’ve got a Curvy which is carbed so you need to re-Jet. Pointys use Injectors so they need to be Re-maped.
Either way with just an end can no need, with both it should be done to get the power gains although it’s not absolutely necessary
This is presuming from your display pics.
Old 09-07-09, 03:16 PM   #7
SUPERSTARDJ01
I don't have it on yet, I have the can and the second pipe (the bendy one) so I have 3/4 of the full system.
Old 09-07-09, 03:18 PM   #8
suzsv650
Should be fine dont worry about it. When its on if the bike runs like crap get it Jetted.
Old 09-07-09, 03:19 PM   #9
SUPERSTARDJ01
Old 09-07-09, 09:39 PM   #10
Kuku
Thanks a lot
jetting trialspaul Mini-Twins 1 18-02-09 07:38 PM
Help with re-jetting Spoon SV Talk, Tuning & Tweaking 14 08-08-08 04:00 PM
blueflame can - jetting? 01 sv650s SV Talk, Tuning & Tweaking 7 26-09-06 12:59 PM
K&N panel jetting 01 sv650s SV Talk, Tuning & Tweaking 5 17-09-06 09:26 PM
re jetting Quiff Wichard SV Talk, Tuning & Tweaking 5 27-05-05 02:06 PM
