Old 25-07-09, 07:44 PM   #1
Gene genie
Default idle, bike that is.
washed my S.V. this morning all ready for a fun ride in the sunshine. bike didn't feel right, all popping and phlut phlut. crawled home in a sorry state.
now i know they're not the best for water ingress in the electrics.
but where do I start looking first.
I'm beginning to feel its the showroom.
Old 25-07-09, 07:51 PM   #2
xXBADGERXx
Default Re: idle, bike that is.
Wet front plug ?
Old 25-07-09, 08:00 PM   #3
Holdup
+1, try and ride round for a bit, locally if your worried about it dieing and not restarting, round your estate etc mine was missing the other day i went out for a ride every time i stopped it kept trying to stall and cut out every so often but once i ridden for a bit it was fine
Old 25-07-09, 08:09 PM   #4
Sean_C
Spray some WD40 in the drainage hole for the front plug. This should get rid of water in there.
Old 25-07-09, 08:54 PM   #5
Gene genie
thanks peeps.
sean, wheres the drainage hole for the front plug??
b.t.w. its a pointy.
Old 25-07-09, 10:57 PM   #6
Sean_C
Originally Posted by Gene genie View Post
thanks peeps.
I have no idea on a pointy, on a curvy its on the riders right, about half way down the cylinder.
Old 26-07-09, 01:07 AM   #7
xXBADGERXx
About the same place on a Pointy as well . I had a similar problem a while back with the bike running like a sack of poo . I ended up buying 2 new plugs and it was fine after that . I think the core on the front plug had degraded to the point of uselessness , I suspect they were the OEM plugs as well and had done around 17k so had been worked hard . Manual suggests a change at 7k , banged 2 new ones in and instantly the bike was spot on .
Old 26-07-09, 06:03 AM   #8
Gene genie
thanks again guys. i think i've located the drainer sean, seen it a million times and never knew what it was for. right then, off t'garage.
Bike will not run past idle Elm74 SV Talk, Tuning & Tweaking 7 23-06-09 02:18 PM
Bike idle struggling hallasv SV Talk, Tuning & Tweaking 4 31-10-08 05:34 PM
I need help - Bike wont idle. TheShadow SV Talk, Tuning & Tweaking 13 08-10-08 02:05 PM
bike wont idle bcsv650s SV Talk, Tuning & Tweaking 5 12-05-06 04:37 PM
My bike wont idle. Freeloader SV Talk, Tuning & Tweaking 6 10-02-06 06:12 PM
