Old 26-07-09, 06:13 PM   #1
mnrsmith
Default Oooooooonnnnnnngoing front end rebuild...
It all started the fork seals looking a bit dodgy...so I took the forks apart. Well then perhaps I thought I should put some tapered roller bearing in as I've got it apart.
Then I might as well get the bottom yoke and fairing bracket powder coated - they looked a bit rusty.
Some good work from triple-s:
Got some gold valves from charlie on here.
Decided to have a go at some fork polishing. One fork done, tried hard to get all the cast marks out:
Saw a polished top yoke on ebay and decided to have a go:
Final polish still to go with this.
I found out polishing is pretty hard work and very messy.
Anyway, as I don't have much time to spend doing all this I've missed all the good weather - hopefully will get it all back together before the summer goes.
Old 26-07-09, 07:06 PM   #2
Default Re: Oooooooonnnnnnngoing front end rebuild...
very shiny... well done...
but you do know that now you are going to have the endless task of keeping it shiny...
Old 29-07-09, 07:38 PM   #3
Nutter
Ooo, shiney! About time you put it back together though!
caliper rebuild help???? arcdef Guildford Massive 13 04-01-09 08:28 PM
Rebuild. John 675 SV Talk, Tuning & Tweaking 15 26-08-08 06:22 PM
Rebuild help needed tradedog SV Talk, Tuning & Tweaking 3 25-02-08 08:16 AM
Continuing rebuild of a SV Grinch SV Talk, Tuning & Tweaking 2 22-06-07 01:36 PM
The rebuild!! Jester666 Soho Massive 2 20-05-07 12:22 PM
